Transfer Case Bushings - Ford Truck Enthusiasts Forums
Old 07-09-2013, 01:39 AM
jjurva! jjurva! is offline
jjurva! is starting off with a positive reputation.
The transfer case on my 1960 f100 4x4 is very loose. I tried just tightening the nuts down a little and ended up stripping out one of the nuts. Anyway, while I'm down there I would like to change the bushings out. The square mounts on the underside seem to be in perfect condition but the round ones on top are very cracked and worn. Where could I get these round bushings? Also do I need to take the t-case off the truck to change them or can I just do one at a time. There seems to be a washer of some sort keeping me from pulling the bushing of the top? Can anyone help me?
Old 07-09-2013, 11:25 AM
theodore/teddy's Avatar
theodore/teddy theodore/teddy is offline
Refyred
theodore/teddy is a splendid one to beholdtheodore/teddy is a splendid one to beholdtheodore/teddy is a splendid one to beholdtheodore/teddy is a splendid one to beholdtheodore/teddy is a splendid one to beholdtheodore/teddy is a splendid one to beholdtheodore/teddy is a splendid one to beholdtheodore/teddy is a splendid one to behold
JJ; IIRC there is a sleeve between the upper and lower isolators. I'm unable to find the parts numbers in my book for these (group 6039?)
Numberdummy should be along shortly to provide you with better info and hopefully a source for these mounts/isolators.
Good luck with your project and you know we like pictures!!
Old 07-09-2013, 11:43 AM
Refyred
Ok I think I got your part #'s
round ones = B9TT-6039-A
square ones= B4Q-7010-B
If you google these numbers you should come up with a supplier.
Good luck!!
Old 07-09-2013, 12:03 PM
Buzz44's Avatar
Buzz44 Buzz44 is offline
Buzz44 has a good reputation on FTE.Buzz44 has a good reputation on FTE.
Im not sure if you have a Dana 24 in your 60. If you do have a dana you might be able to get new TC case bushings from the bronco graveyard. Web site is bronco graveyard .com or google it. I have to replace the ones on my 65 dana as with out good isolaters I get a lot of noise transferred to the frame and into the cab.
Old 07-12-2013, 11:15 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
See pic below .. do you also need 7A053?
B9TZ-6039-A (replaced B9TT-6039-A) .. Transfer Case Insulator-Round / Obsolete
GREEN SALES CO. in Cincinnati OH has 13 = 800-543-4959.
B9TT-6039-A =
CARPENTER NOS OBSOLETE PARTS in Concord NC has 346 = 800-476-9653.
B4Q-7010-B .. Transfer Case Insulator-Square / Obsolete
ARCHIE COCHRANE FORD in Billings MT has 2 = 800-473-2286.
COTTAM-WALKER FORD in Taos NM has 4 = 575-751-3200 x206.
LARRY H. MILLER FORD in Salt Lake City UT has 4 = 800-950-5006.
GREEN SALES CO. has 15.
GOODE MOTOR CO. in Burley ID has 17 = 208-878-5611,
Old 07-12-2013, 01:39 PM
Thanks for the help! I have all the 7A053. Do i need to replace them? I searched for B9TZ-6039-A on the sites you said have them and nothing came up.
Old 07-12-2013, 03:58 PM
How did you perform this search...using a ouija board?
I looked up the part numbers, typed them into three parts locator sites, none of which you've probably ever heard of:
Ford Dealer Parts Locator System, rearcounter.com & PartsVoice.com .. then gave you the info.
CALL the sources and ask, that's why I listed the phone numbers. Both Carpenter & Green have toll free 800 numbers, so it won't cost you a dime.
Go to: greensalescompany.com .. type the part number (B9TZ6039A like this, no spaces or hyphens) into their search box = THIRTEEN AVAILABLE.
Old 07-12-2013, 04:45 PM
Ouija board haha funny I enjoy the humor. Just searched the part numbers in the search box at the company websites. must have been because i searched the numbers using the hyphens too. Thanks again. It would have taken me forever to find these parts!
Old 07-12-2013, 11:58 PM
They actually had my parts at my local napa auto parts store for a decent price! Know that I have that figured out how do I remove the studs? I don't really want to use vice grips because I want to save the stud. The double nut method?
Old 07-13-2013, 01:05 PM
spurredon's Avatar
spurredon spurredon is offline
spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.
Double nut method has usually worked for me. You can always help things along with a little heat too.
Old 07-24-2013, 05:59 PM
idaho211 idaho211 is offline
idaho211 is starting off with a positive reputation.
Probably too late of a reply but they are available at NAPA new, let me know if anyone is interested I will post the part number.
Old 07-25-2013, 05:27 AM
Quote:
Did'ja read post 9? The OP already got 'em from NAPA
Old 07-26-2013, 02:17 AM
The transfer case is no longer loose with the new insulators! However I am still getting some vibration as I accelerate. I changed all the u joints. Any ideas?
Old 07-26-2013, 09:02 PM
spurredon's Avatar
Have you checked the ubolts?
Old 07-27-2013, 03:23 AM
Not yet but I will! Any idea what the torque specs on that would be?
F350 2wd Radius Arm Bushings - Tricks and Chronology frederic 1987 - 1996 F150 & Larger F-Series Trucks 6 07-27-2016 10:04 AM
92 F150 4X4 won't start w/ clutch in and hard to shift milehieagle 1987 - 1996 F150 & Larger F-Series Trucks 1 01-01-2015 11:05 AM
Bushing locate help? MontanaboyDesigns 1973 - 1979 F-100 & Larger F-Series Trucks 4 12-03-2014 10:12 AM
Radius arm bushing replacement Mustangking1 1973 - 1979 F-100 & Larger F-Series Trucks 17 02-22-2014 08:02 PM
transfer case bushings 66crawler 1961 - 1966 F-100 & Larger F-Series Trucks 12 03-11-2012 06:10 PM
Tags
f100, loose, transfer case
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
