F600 Steering Box
Welcome to FTE
Which parts? 1957/60 F350/600 same gearbox (B7Y-3504-A).
Left: Steering gearbox / Right: Parts list #9 / No Ford Dealer or obsolete parts vendor has B7Y-3524-A
Upper/lower steering shaft bearing cups & bearings & seal; sector shaft & bushings & gasket & seal available NOS
I'll list the part numbers/sources if this is what you want.
Bill will hook you up, BUT you just might get a bad case of indigestion. I'll admit, he's been uncharacteristically cheerful lately, though.
I usually keep some Carters Liver Pills close by, in case he turns rogue.
Though they've been defunct for years, I was wise enough to stock up as soon as I met Bill.LOL!
Welcome to FTE.
Welcome to FTE.
Look up meteorism in the dictionary, then fill in the blank with the apropos slang word: Carter's little ______ starters.
Oh, I figured it out alright, just didn't want to say it out loud for those that may tring to come up with it. Flatulence promotion I think!
Larry,
One idea would be to find a good used one. Some of the parts to rebuild are pretty expensive. I spent $450-500 to rebuild one. Too bad you aren't closer. I pulled a very good complete steering box from a F600 farm truck. With the new road safety specs around here farmers are selling these trucks and if you can get them before they go to the crusher you would be able get a decent box. Good luck.
