Which transmission do I have? - Ford Truck Enthusiasts Forums
Old 06-18-2002, 03:52 PM
John7894's Avatar
John7894 John7894 is offline
John7894 is gaining momentum as a positive member of FTE.
Old 07-13-2002, 11:26 PM
ahkmn ahkmn is offline
ahkmn is starting off with a positive reputation.
I have a 1995 Ford F-150, 4x4, 5spd, with a 4.9 inline-6. It just rolled over 194,000 today. I changed the oil in it today, and I was inspecting it and I noticed that on my transfer case, down by the drain plug, there is a nice little hairline crack coming from the plug. Whoever the idiot was that changed it last must have used an impact wrench on it!
Anyway, if this motor ever decides to quit on me, which it probably never will, I am looking at a few different possibilities for an engine swap. First things first, can anybody tell me what transmission I have now? The numbers I found on it are as follows:
F1TA
GC
B805916
The transfer case numbers are as follows:
Borg Warner
13-56-065-910(I am assuming this is either a part # or a casting #)
On the tag on one of the rear bolts:
BO25 1 1356-78
160258 F5TA-HA
Old 07-14-2002, 07:39 AM
ftrain ftrain is offline
ftrain is starting off with a positive reputation.
I am sure there are books out there with those numbers, but if you are the original owner, and/or you are sure the tranny has never been swapped, you can get a code off of the sticker on the inside of the door on the driver's side...The stickers should have something like a heading that reads "trans" and a code underneath that...
Give us that code, and it will likely be a quicker ID...
1987 F150 Reg Cab, 302MFI, AOD, 3.55 Rear, K&N Filter
http://www.ford-trucks.com/user_gallery/displaythumbnail.php?&photoid=4972&.jpg
Old 07-14-2002, 11:05 AM
Motorcraft Motorcraft is offline
Motorcraft is starting off with a positive reputation.
I am going to say you have the Mazda Tranny with the inline 6 and it being a F150 I have a 302 and i have the mazda. If it were a F250 it could have had the ZF tranny.
Old 07-14-2002, 03:07 PM
What can you tell me from this?:
Trans: M
Axle: 19
Springs: KI
Also, what axle do I have and what can you tell me about the springs from this code?
Thanks.
Old 07-14-2002, 04:20 PM
OK you have a Mazda Tranny 3.55 rear end NON limited slip and the spring codes just give me part numbers. I go this info from a Ford Service CD i bought off Ebay for 15bucks. It comes in handy you should look into getting one.
Old 07-14-2002, 05:25 PM
What kind of horsepower and torque limits are we talking for a tranny like this?
Old 07-14-2002, 05:57 PM
I have 275 give or take a few and it does fine. I would say if you go more then like 300+ you might want a ZF but i am not really sure on this.
Old 07-14-2002, 06:17 PM
are you talking hp or ft-lbs?
Old 07-14-2002, 06:57 PM
HP i forgot what i had for tq LOL
Old 07-14-2002, 07:43 PM
I'm not sure about hp yet, but I will probably be running in the 400 ft-lb range.
**** bradphx 1973 - 1979 F-100 & Larger F-Series Trucks 59 12-05-2016 04:27 PM
Can someone explain this to me? 1987 - 1996 F150 & Larger F-Series Trucks 11 03-09-2016 01:40 PM
ooops Aerostar 5 01-14-2015 04:16 AM
... miko6810 Modular V10 (6.8l) 9 06-04-2014 07:14 AM
Superchargers walterdanek Ford Inline Six, 200, 250, 4.9L / 300 16 02-16-2001 08:56 PM
Tags
135678, 1995, 302, 49l, 96, borg, codes, f150, f1ta, f250, ford, kind, ratio, read, tranny, transmission, warner
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
