Any tips to shift NP205?
I rebuilt my NP205 and it seems to index fine out of the truck -- but when I put it in the truck, it's a completely "pull and pray" every time I need to get it into a different gear. Sometimes I can feel a firm click or two but I never know where it's going to end up....
Sometimes all the way up clicks it right into 4L and sometimes all the way down is still in neutral. Sometimes it shifts while in park, sometimes in neutral and sometimes only while I'm in drive while I "blip" the throttle to try and get it to shift.
Usually, every time I'm about ready to drive off the road in anger, she'll click into the gear I'm looking for.
It's a 460 w/ a C6 and a divorced NP205. Any tips??
Ughhh.... Shifted into 4-low last night to pull some stumps and can't get it out. Drove around the block 3 times trying R/N/D/Park and yanking, cursing and punching the shifter. Crawled under it afterwards and had the girlfriend try to push on it and it's just not going.....
Though more often than not you can get away with leaving the hubs locked and disengage 4wd just fine.
Its usually takes a little pressure and a blip of the throttle for me and mine. Try that and have you tried it with the truck reverse? Have you tried to turn the truck off and leave the trans in N ?
"Drive around the block" I hope it was NOT on pavement. Was it this way before you rebuilt it?
