what is my truck doing?
I have an 09 F250 6.4 PSD. A little history on the truck. I bought it used with 32k miles jan 2011. Since I bought it we have been faithful about oil changes and fuel filter changes (last did both approx 2000 mi ago). These have been done at the ford dealership. We are also pretty good about draining the water monthly (always very little to none in it). I also run Diesel kleen+Cetane boost in it with most fuel ups (unless I ran out and haven't been able to get to store) It has a known regen issue where it regents frequently especially in cold wet weather and smokes badly when doing so in the cold wet weather. When I did the last oil and fuel filter change thy also updated the programming as per a service bulletin for that issue. It still regens approx 1 x week and for about 23-26 mi of highway each time (I drive 30 mi each way to work, mostly highway). I tow a 7000 lb travel trailer approx 1x month a few hours each way (we will be driving it NC to FL in aug towing the trailer).
ok now to the current issue, I have been noticing the truck off and on suddenly feeling like someone is pulling on it to slow it down and then just as suddenly it almost jumps and stops doing it. It can do it randomly or when going in and out of regen. I notice less power when in regen Also. Is this a fuel issue, tranny issue, regen issue, or what? I have 60K on the truck and a 5yr/100,000k extended warranty. Should i be worried about towing my trailer to disney from NC next month? Thanks
I would log regens, length, space between them.
Hand calculated mpgs over the route you travel, specify
And boost pressures. Loaded or unloaded. Chart it for a week and present it.
Mine along time ago was doing more regens then I thought it should. It was also pushing more boost then it used to it.
End result was a new high pressure turbo as it was out of spec. No check engine lights or codes. Just my butt saying something was not right. Dealer did a diagnostics and that is what it was. Warranty repair.
id be curoius how the air filter is. you should be able to read the filter minder to see if it has been sucking to hard also. its mounted right on the air filter housing. i do believe they had some that where too sensitive tho if i recall correctly. but 30k miles depending on the driving conditions,changing that filter could be a very easy quick fix to see if thats all it is.
