Mazda trans on f 150 1993 tuck - Ford Truck Enthusiasts Forums
Old 07-08-2013, 05:13 PM
jefe197 jefe197 is offline
jefe197 is starting off with a positive reputation.
Cool Mazda trans on f 150 1993 tuck
I need help with my f 150 the trans goes into 1 gear but the truck won't move same on 2 gears on 3 the truck moves I install new clutch same some body may have a idea what could be the trans is a 5 speed mazda trans thanks
Old 07-09-2013, 03:15 PM
Encho's Avatar
Encho Encho is online now
The Southernmost Mod
Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.
I posted your question in the right place, follow this link to get to the proper Chapter for your truck: 1987 - 1996 F150 & Larger F-Series Trucks - Ford Truck Enthusiasts Forums
And this is the specific thread I made for you, post a message there and you'll receive any updates when others answer your question, just have some patience: http://www.ford-trucks.com/forums/12...l#post13325094
94 f150 truck computer freerev 1987 - 1996 F150 & Larger F-Series Trucks 1 03-16-2014 09:22 PM
Swap M5OD Mazda to ZF 5 speed in a f150 is it a direct bolt up Jason302 1987 - 1996 F150 & Larger F-Series Trucks 32 01-12-2014 12:24 PM
Putting a ZF 5 speed in a 1996 F-150 Torchin' an Truckin' 1987 - 1996 F150 & Larger F-Series Trucks 4 07-19-2010 10:42 AM
Mazda 5-speed blues cowchasinsix Clutch, Transmission, Differential, Axle & Transfer Case 20 02-12-2010 02:57 PM
Mazda 5 Speed Compatability Question anthony605 1987 - 1996 F150 & Larger F-Series Trucks 8 12-28-2005 03:54 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
