HyperTech programers no good on V-10 - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 07-08-2013, 04:01 PM
rick700raptor rick700raptor is offline
rick700raptor is starting off with a positive reputation.
Thumbs down HyperTech programers no good on V-10
If you are looking for increased performance for your V-10 do NOT buy Hypertech programmers.
Especially if you have a cat Back exhaust system and or a cold air intake.
And if you tow heavy loads in the Mountains such as Oregon like I do.
I had a lot of problems with mine and finally returned to stock settings.
A free flowing exhaust and cold air intakes lean the engine out and Hypertech uses a car like tune, which leans the motor out even further.
This created pre detonation spark knock (which if bad enough can burn holes in the tops of pistons) while I was towing heavy up long steep hills. I re programmed it to the regular setting, but the timing curve was still to aggressive for towing up steep grades it still pinged badly. I was using Premium fuel the whole time.
I actually lost towing power with Hypertech, regardless of what setting I used. I have had it over 30 days so they will not refund my purchase price either, so much for their products and customer service.
I spoke to their tech guys, and he convinced me it was a good tune for a car, and I tried to convince him it was a horrible tune for a truck while towing.
My truck was already lean and Hypertech made it worse, I thought they would have a provision to Rich-en up the fuel ratio for such obvious conditions, But they do not.
Do Not buy trouble guys, thats all Hypertech was for me. Since they wont refund my cost, Id like to sell it, but in all good conscience, I would not feel right selling my Hypetech problems to someone else.
I thought a programmer would be more programmable, but its not much better that a pre programmed chip. IN this case the program was a very bad fit for the application. they just pre set the tune for a car like application ignoring what trucks do in reality.
Stay away for Hypertech. Its all hype and ill fitting tech.
Old 07-08-2013, 04:08 PM
Toreador_Diesel's Avatar
Toreador_Diesel Toreador_Diesel is offline
Toreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputation
Certain tunes require premium fuel, so you may try that. However, Mike at 5 Star tuning works wonders for the V10 and most of Ford's other gas motors.
Old 07-08-2013, 04:54 PM
Yes I used premium gas to no avail, even with their so called regular tune.
thanks for the heads up on Mikes, I will check it out.
Old 07-08-2013, 05:33 PM
redford's Avatar
redford redford is offline
redford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputation
Quote:
Originally Posted by rick700raptor View Post
...I spoke to their tech guys, and he convinced me it was a good tune for a car, and I tried to convince him it was a horrible tune for a truck while towing.
I think I might have asked the technical representative to point out which "car" in the Ford lineup came with a V-10.
Old 07-08-2013, 05:39 PM
Huh? Wrong post?
Old 07-08-2013, 06:36 PM
mudfuel06's Avatar
mudfuel06 mudfuel06 is offline
mudfuel06 is starting off with a positive reputation.
He was referring to the car like tune you stated the rep told you. As for a programmer, if you don't use Mike, then you may as well keep throwing money away. His tunes will wake up the V10, no matter the year. Just don't expect any mpg gains, the BSEG wipes those away very quickly.
Old 07-09-2013, 03:24 PM
Ah OK I got it, well I am trying to get money back from Hypertech, I contacted Mike, if he cant help me I will leave the computer alone. No I am looking for heavy towing power not MPG.
S/B cold air return gstaz Air Intakes, Air Filters & Ram Air 0 10-14-2016 10:50 AM
Excursion/F-250 V-10 Hypertech programmer rick700raptor Modular V10 (6.8l) 35 01-25-2012 07:38 PM
Will hypertech harm my engine Lance4986 6.0L Power Stroke Diesel 11 12-05-2011 08:14 AM
hypertech programer kx125str99 Computer Chips & Tuners 4 08-02-2011 09:12 AM
Hypertech power programming and towing fordf350lvr 1999 - 2003 7.3L Power Stroke Diesel 16 08-30-2003 06:58 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
