P026A - anyone had this code show up? - Ford Truck Enthusiasts Forums
Old 07-08-2013, 03:42 PM
mebe2k's Avatar
mebe2k mebe2k is offline
mebe2k is gaining momentum as a positive member of FTE.
took my new/old 36' 5th wheel for it's first trip from Phoenix, AZ to Laughlin, NV.. truck ran very well and pulls the hills great...gets about 8-10 mpg while pulling the 12K trailer..however...on the way back, stopped for fuel in Kingman, AZ, got on i40 and had the Check Engine/MIL light come on.. first thought was, not another stupid EGT sensor...stopped into Jones Ford in Wickenburg, AZ, and the mechanic came out and hooked his laptop up and started scanning for codes..P026A - Charge Air Cooler Efficiency Below Threshold - comes up. the mechanic said that it's probably a sensor for the air charge cooler...but he would need the truck overnight to check for sure..I asked him if it would be alright to keep on going to Phoenix..he said yes, that it might have got too hot and that is why it set that code(it was very hot 110+)..he cleared the code and I was on my way back to phoenix..
Well... took the trailer for a trip up to Utah, and not even 1/4 way into the trip, the MIL/Check engine light comes on again..checked it with my OBD/CAN scanner and P026A again...looks like another trip to the dealer. the problem doesn't seem to change the way the engine runs, although it seemed like it was getting lower MPG's, after the MIL/check engine light came on..anyone else had this code/issue come up? the mechanic at jones ford said this was the first time he had seen this code come up on a 6.7..
Old 07-30-2013, 11:10 PM
Howard.Judd Howard.Judd is offline
Howard.Judd is starting off with a positive reputation.
I had that code turn up on mine today. The tech at my local dealer checked the troubleshooting manual and it said to first check the coolant level in the secondary cooling system. He did and mine was very low. Topped it off with coolant, cleared the code and all is well for now. Bad thing is he also told me the only time he had ever seen one lose coolant from the secondary cooling system it was because the EGR cooler was leaking. So, I'm going to monitor the level for a couple of days and check for external leaks before I take it back. At least I think it's still covered under warranty.
Old 07-31-2013, 02:02 PM
mebe2k's Avatar
Mine was the sensor for the air charge cooler.. Just like the first mechanic said..ford must've used some really cheesy sensors on these trucks.. SO far 2 egt sensors and now the air charge cooler sensor,.
Old 10-24-2016, 05:48 PM
70amcpwr 70amcpwr is offline
70amcpwr is starting off with a positive reputation.
Mine tripped the same code last week towing our 38' 5th wheel. I did happen when the clutch fan was operating. I happened to see the light come on, just as it did there was a spike in the boost gauge of almost 10 psi. Don't know if that's relevant or not. I cleared it and it didn't come back in about another 700 miles of hard towing (75-80 mph traffic on I95 south). I guess I'll wait and see???
Old 11-30-2016, 04:31 PM
Murray Metherell Murray Metherell is offline
Murray Metherell is starting off with a positive reputation.
My light has been off and in for the last 10k miles. it comes on when I'm pulling but usually goes of in a day or 2 after. just bought a scanner to find what it was. ...after reading this I'm not much smarter.....lol. it doesn't seam to have the power it should but I really don't have anything concrete to base it on .
Old 12-07-2016, 07:43 PM
cabindoc's Avatar
cabindoc cabindoc is offline
cabindoc has a very good reputation on FTE.cabindoc has a very good reputation on FTE.cabindoc has a very good reputation on FTE.
I was loosing coolant from secondary cooling system. Turned out to be secondary water pump. Bout $500 parts/labor
2009 F250 PRNDL Lights of Death bagman7 1999 to 2016 Super Duty 0 02-06-2017 10:25 AM
Please Help with engine stalling Roscoe316 6.0L Power Stroke Diesel 28 10-21-2016 08:51 PM
We Just Drove 2650 miles with a Ford w/320,000 miles Sand Obsessed Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 1 09-17-2015 02:40 PM
code p0420 - hard cold start franklin411 Explorer, Sport Trac, Mountaineer & Aviator 6 05-11-2003 05:18 PM
97 Expedition DTC Codes P1131 and P1132 jamillertriathlete Modular V8 (4.6L, 5.4L) 2 12-06-2002 12:28 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
