Since I got my truck a few weeks ago, I've been changing out the fluids as I have no idea if/when the previous owner did, so I want to start out with a clean slate. Being the first manual I've ever owned, I don't know what kind of transmission fluid to use. All of the fluid at the auto parts stores says "For Automatic Transmissions". I have found what Chiltons says is recommended: MERCON (Dexron II), but again, say "for auto transmissions". Does it matter that it says that?
That's what it takes, use it with confidence. Also, you're not likely to find M/D II. It's been superseded and I think we're up to M/D V. That IS a direct replacement and is what you want.
to joeged, please check again, is it really a manual?...I have worked on all my vehicles since 1956, never knew of anyone using automatic trans. fluid in a manual....jerry
I typed that wrong above. The Chiltons manual says to use MERCON (DexronII) ATF on all 5-speed manual transmissions. Obviously, ATF stands for Auto Trans Fluid, but it doesn't make sense to use that for a manual trans.
so you were refering to the chilton manual, when you said its the first manual..? but your truck has a 5 speed automatic transmission?..sorry about rambling,..did'nt want you to waste the wrong fluid or maybe harm some bearings.....jerry
This is CORRECT, 90w gear oil is too thick for the later transmissions, it WILL cause problems shifting and maybe just kill a bearing or two..Use the recommended ATF....
It is, after all, what Ford recommends. I wanted to get some synthetic oil due to the trans having almost 100,000 miles, but the guy at the auto parts store suggested to go with manufacturers suggestion.
