smells like antifreeze
Old 07-07-2013, 08:15 PM
coatit's Avatar
coatit
coatit is offline
Cool smells like antifreeze
smells like antifreeze but i can't find any leaks or wet spots on the carpet and the coolant level is good where should I look.Just replaced heater core last winter. HELP
Old 07-07-2013, 09:05 PM
bigdaddyII's Avatar
bigdaddyII
bigdaddyII is offline
Smells like antifreeze in the cab? If so it sounds like a heater core issue. It doesn't take much antifreeze to smell up the cab. You really had to have the heater core replaced?
Old 07-07-2013, 09:12 PM
coatit's Avatar
coatit
coatit is offline
yes just did that back in february, cost near $1000.00
Old 07-07-2013, 09:49 PM
Cubawashere's Avatar
Cubawashere
Cubawashere is offline
do you have access to a coolant pressure tester? Pressurize the system and be sure there is a leak and pressure doesn't hold. Otherwise it does sound like core issue. Possible defect or someone damaged it upon install? Sounds like for a whole $1000. bucks though, better be a hell of a warranty with that job! Sorry to hear and Good luck!
Old 07-08-2013, 07:08 AM
tseekins's Avatar
tseekins
tseekins is offline
Received 1,221 Likes on 803 Posts
On the new trucks, there's a ton of labor involved just to get to the heater core.
Old 07-08-2013, 07:30 AM
Cubawashere
Lucky for me, I haven't gotten to work on any of those yet. The worse one by far for me to date was on a Blazer, don't remember what year it was, but had to physically cut the A/C box and remove fender well as per Chevy among other things.... 2 day job there...the only thing I learned was that I NEVER wanted to do another one on them....lol
Old 07-08-2013, 08:19 AM
Turbo Dog's Avatar
Turbo Dog
Turbo Dog is offline
Like they said up above it only takes a few drops in the heater box to smell.
The worst heater core I ever replaced took a week 8 hours a day! That was a Lotus Espirt S3...It is the first item put on the chassis before they build the fiberglass body. I had to drill out the rivets to remove the hand wrapped leather dash, then the entire heater/ac dust system, then I had to cut out the entire firewall. The owner came in and saw his car torn apart and hit the roof.
Old 07-08-2013, 01:00 PM
Cubawashere
Heck of an accomplishment right there!!! LMAO on the reaction of the customer!! Livid I'm sure.... hands down, I bet you'll never want to do that job again...lol
Unbelievable the way they make cars...especially trying to access important parts that do wear such as the core.... Thanks for your story of your worst core experience!
Old 07-11-2013, 10:27 AM
Turbo Dog's Avatar
Turbo Dog
That was back before they were fuel injected so they had dual side draft 4 barrel carbs on a turbo powered 4 cylinder engine. If I tuned one up I would hope the owner would pick it up that day. It only took slight barometric pressure changes to throw off the tuning.
Spidsns
10-01-2016 12:09 PM
Robby Nash
1999 to 2016 Super Duty
07-18-2012 07:55 PM
PLNTKLR
06-24-2009 12:00 AM
windsor94
17
11-10-2008 12:51 AM
ford429cu
1983 - 2012 Ranger & B-Series
09-16-2006 01:24 PM
Quick Reply: smells like antifreeze
