A.C. compressor shakes
Ref. 75 F-150, 390, factory air.
When we bought it in April, the compressor shook and sounded like it was
ready to blow up. I had it evacuated. I installed a new receiver/dryer and
a rebuilt compressor (less clutch) from Advance Auto Parts. The local
a.c. shop evacuated the system and installed 2.4lb of 134A. for $80.
(Did I say the system was converted to 134A by an a.c. shop in 97.)
The replacement compressor shook and rattled just like the original.
The shop evacuated the system again. I exchanged the compressor under
warranty, installed it, had it evacuated and charged with 2.4lb of 134A for $50.
I get the same shakes and rattles as the original compressor.
W H Y ?
The compressor is installed upright, not on it's side.
W H Y ?
Also, this setup has two idler pulleys, the one that's used to tighten the belt then a second that is located kinda down between the water pump and power steering pump. This one is fixed, not adjustable. It's sole purpose is to keep the belt from vibrating and causing problems. Without it the span between the compressor and crank pulley is way too long and allows the belt to vibrate really bad.
If it were mine, I'd bite the bullet and convert to a Sanden style compressor. Light, smooth, efficient and quite.
And they're cheaper than York. A rebuilt York is usually $200 or more. A new Sanden style is around $185 including clutch and pulley.
The conversion is not complicated at all.
Here is a link to my conversion thread, this was also a 390.
https://www.ford-trucks.com/forums/1...onversion.html
jimschor
11-01-2015 09:35 PM
octaneforce
03-22-2009 01:49 PM
