Hydro Boost - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Hydro Boost
Old 07-07-2013, 03:48 PM
Big Sky's Avatar
Big Sky Big Sky is offline
Big Sky has a good reputation on FTE.Big Sky has a good reputation on FTE.
Hydro Boost
Has anyone on here replaced their hydroboost? The reason I ask is that on my Excursion, the brake pedal doesn't feel as firm as before, I replaced the power steering pump since it was making noise, and that helped for awhile but now is not as firm. Fairly intermittent..
Old 07-07-2013, 03:54 PM
mueckster's Avatar
mueckster mueckster is offline
aka Redneck Wrencher
mueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputation
Have you bled the brakes? Does the pedal drop?
Old 07-07-2013, 04:28 PM
A/Ox4's Avatar
A/Ox4 A/Ox4 is offline
9 ECHO 1
A/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputation
Have you flushed your power steering fluid? Believe it or not, they are related.
Old 07-07-2013, 04:41 PM
Punisher29073's Avatar
Punisher29073 Punisher29073 is offline
Punisher29073 is starting off with a positive reputation.
Usually when a hydro boost unit goes out the pedal will be hard as a rock, just like a vacuum booster. I would look at pads or hoses maybe. Air in the line will doe that as well. Bleed first me thinks.
Ryan
Aftermarket Fuel Injection..(Holley). ozark1 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 4 09-18-2015 01:52 PM
Brake pedal goes to floor only when engine running Fords412 1999 to 2016 Super Duty 16 11-02-2011 12:07 PM
y pipe removal jirwin 1999 - 2003 7.3L Power Stroke Diesel 11 10-18-2010 06:30 PM
Pump the brakes to get a firm pedal? cabloom300 1973 - 1979 F-100 & Larger F-Series Trucks 9 06-24-2010 04:42 PM
Sonnax Valve/Tricumulator Springs or Transgo Kit nhancock 1999 - 2003 7.3L Power Stroke Diesel 3 12-17-2004 08:43 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
