Fuel Filter Check Valve Tower
Old 07-07-2013, 11:19 AM
Cell's's Avatar
Cell's
Cell's is offline
Question Fuel Filter Check Valve Tower
Where can I buy a new fuel filter check valve tower and all the related parts , especially the spring ??
I am rebuilding my fuel bowl and when I got to taking apart the check valve tower in the fuel bowl , I LOST THE DARN SPRING and can't find it .
Now I gotta find a new one where ??
Thank-you for your replies .
Old 07-07-2013, 11:27 AM
woodnthings's Avatar
woodnthings
woodnthings is offline
Well the good part is the spring and check valve are not needed. The idea behind the design is to eliminate the chance that you can run the truck without a fuel filter. The spring closes the check valve when no filter is installed and when you install a filter it compresses and opens up. You could probably just get a spring locally and make it work.
Old 07-07-2013, 11:44 AM
Cell's's Avatar
Cell's
Cell's is offline
So if I put any spring in there close enough to the original , the truck should run .
I will put it back together and see if it will run with no issues .
Other then that , I guess I will have to go to a scrap yard to try and find one .
Old 07-07-2013, 11:45 AM
dn29626's Avatar
dn29626
dn29626 is offline
I agree with woodnthings.
However, if you want one the stealership sells them.
Old 07-07-2013, 11:53 AM
BigAlsPSD's Avatar
BigAlsPSD
BigAlsPSD is offline
Bob has them as well, if you want to replace it.
CHECK VALVE STAND PIPE 1994 1/2 - 1998 Ford Vans and Pickup
Old 07-07-2013, 11:59 AM
woodnthings
Al, That one is for the OBS trucks. I didn't see the SD one, but Bob may very well sell it.
Old 07-07-2013, 12:14 PM
BigAlsPSD's Avatar
BigAlsPSD
Oops, good catch, didn't even really look at the part, apologies to the OP.
Old 07-07-2013, 02:25 PM
A/Ox4's Avatar
A/Ox4
A/Ox4 is online now
9 ECHO 1
Like woodsnthings said, you don't actually need it if you don't want it. Just don't try to run the truck without a filter.
Old 07-07-2013, 02:38 PM
srteach's Avatar
srteach
srteach is offline
I have been running without the spring for about a year now. Don't need it.
That spring mechanically closes off the fuel supply when the wrong (or no) filter is installed. The correct filter has a push pin in the center to push the spring cap down. Some filters have too short of a pin or no pin to let fuel in the bowl, and won't work with the engine.
Old 07-07-2013, 03:26 PM
Cell's's Avatar
Cell's
Cell's is offline
Thank-you all for your replies !
I put the truck back together with a spring that I found in a buch of spare parts . Not the exact spring but one that was close to it . I had to guesstimate the length that I had to cut the spring . I must have made close to the right length because the truck started up with no leaking and I was able to take it for a drive with no issues .
Thanks again !!
pwstroker69
12-19-2015 11:54 AM
Traildust
06-15-2014 08:34 PM
swampfire79
10-16-2013 04:27 PM
KonaGrown
03-03-2012 11:05 AM
dcon12
08-16-2010 07:39 AM
Quick Reply: Fuel Filter Check Valve Tower
