87 F250 with semi float axle. I have a set of American Racing AR62 wheels you know the trick wheel all the holes and because they are about a half inch thick the lug studs seem way too short. According to what I have read the ar62 uses acorn style lug nuts so not like typical mag wheel lug nuts that go into the wheel. Just curious if anyone else has run into this and how did you remedy the issue? Because i dont like the fact that the hang half off the lug stud when they make contact with the wheel. Not enough threads holding nuts on.
the outlaw II first came out they where a shank style wheel so if you have a old set they don't use acorns post up a pic and will see what style they are
Not sure how to post pics or if i even can doing this from my phone. But i am betting i have the old shank style wheels the bolt holes measure 3/4 of an inch now to find shank lug nuts with 9/16-18 threads
