06 f250 fan clutch roaring on acceleration
Hi guys I'm new to the forums I have a 06 6.0 with 340000 miles on it believe it or not still pulls great. The problem is my clutch fan keeps roaring when I press the gas it's extremely loud all my gauges are fine so the truck isn't overheating has anyone else had the same problem? Also not a bad fan clutch I wasted 300 bucks on that and it's still doing the same thing.
The dash gauges are worthless. It could be bad but you need to
know what the RPM of the fan is and the temp of the coolant for starters.
Come on over to https://www.ford-trucks.com/forums/forum107/
you will get more 6.0 info there.
Sean
Sean
Awesome
Mine started doing the same thing recently. Mostly with the AC on. Run an Edge Insight to monitor temps. Coolant at 187-190, oil just a few degrees higher. Did the same thing right after egr delete a year and a half ago. Plugged egr sensor back in and went back to normal. Sensor just laying there plugged in right now. Have AE, any idea what readings I should be looking at?
