2005 F-250 King Ranch 5.4 won't crank - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 07-06-2013, 11:27 PM
bipolarroller bipolarroller is offline
bipolarroller is starting off with a positive reputation.
hi...i have a 2005 f-250 5.4 triton engine...my problem occurs when i turn the key to start the pickup....i get a clicking sound and then nothing....when i use a portable jump starter, it fires right up...on the other hand, when i try to jump from a running vehicle i only get a clicking sound from the starter...
not sure what i should be testing...also, when i bought the vehicle it had been sitting for several months...for my test drive, they used a commercial charger/starter to fire the truck...i drove it about 10 miles, stopped, turned off the motor and 10 minutes later it wouldn't start...when i contacted the owner, he drove to me and "reset" the kill switch under the fuse box in the cab and then jump started the truck...i drove it 40 miles home and for 4 days had no starting issues...on day 5 forward, i have had to use the portable jump starter every time...my battery shows 13 amps resting and drops to 5 amps when i try to start without portable jump starter...when i start it with the portable jump starter, it only drops to 10 amps...
thanks in advance for any insight...
tom
Old 07-07-2013, 12:10 AM
Hotpocket's Avatar
Hotpocket Hotpocket is offline
Hotpocket has a good reputation on FTE.Hotpocket has a good reputation on FTE.Hotpocket has a good reputation on FTE.
you mean volts not amps?
Old 07-07-2013, 12:22 AM
you are correct sir...volts not amps...thank you
Old 07-07-2013, 01:29 AM
Jameson JC Jameson JC is offline
Jameson JC is gaining momentum as a positive member of FTE.
Maybe just toss a new battery in to take that out of the equation?
JC
Old 07-07-2013, 01:35 AM
Hotpocket's Avatar
Quote:
JC
not if the old one is reading 13 volts
Old 07-07-2013, 01:37 AM
Hotpocket's Avatar
maybe try cleaning your connections and make sure they are tight
Old 07-07-2013, 01:39 AM
Battery checked out by autozone as o.k....whats weird is that is cranks right over with the portable jump start but won't even crank a little bit with a jump start from another vehicle....matter of fact, i swapped batteries out with a new one my friend has and same problem...but again cranks right over with the portable...i
ty for replying
Old 07-07-2013, 01:46 AM
thanks Hotpocket...the connections look good, but in another forum i read where looks can be deceiving when it comes to battery cable connections....so with that said, i am going down that road first thing in the morning....especially since i don't have to dive into my wallet...again...
what do you know about kill switches and their potential problems?
i appreciate your replies...ty
02 F250 Wont Turn over 5.4L driveguy 1999 to 2016 Super Duty 5 02-20-2015 06:39 PM
2001 King Ranch with 5.4L Full Battery but No Start! UPDATE: Bad Starter thegreatgate 1997 - 2003 F150 18 02-04-2015 08:24 PM
Beyond Lost and Confused for Starting nate315 1999 - 2003 7.3L Power Stroke Diesel 22 12-02-2014 05:47 PM
Jump Packs Crazyotto1 General Diesel Discussion 6 10-07-2013 03:06 PM
1996 F-250 7.3L Issues with the Starter BuckHammer 1994.5 - 1997 7.3L Power Stroke Diesel 55 01-31-2011 01:59 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
