Turbo hoses and boots
Old 07-06-2013, 10:28 AM
woodtrucker's Avatar
woodtrucker
woodtrucker is offline
I have some really old boots and hoses on my y pipe and intake. Found links to replacements right here on forum! Thanks!
Want to replace them and have one question. I have one bad clamp on the Ypipe that goes into the turbo. The clamp is stripped but it's one of those special clamps.
also, this clamp looks to me to be the type that requires a gasket between flanges on ypipe and turbo. If I am correct, where would one find that gasket and what is it called? and the clamp of course! Thanks much!
Old 07-06-2013, 10:36 AM
pilgrimbizket's Avatar
pilgrimbizket
pilgrimbizket is offline
I don't think there is a gasket.
I would try;
Ford, or a junkyard
I'm not sure but you could also try LMC and Bronco graveyard
Old 07-06-2013, 10:52 AM
Midwest Dually's Avatar
Midwest Dually
Midwest Dually is offline
Diesel O-Rings... Guzzler...
F4TZ 8287 B Ford Turbo Outlet V-Band Clamp 1994.5 through 1997
I have bought a lot from him in the past.. Pricing is good, and he ships quickly!
BTW.. He also has the factory fuel hoses you had the leak on your pump too, and inexpensively too!
Old 07-06-2013, 10:54 AM
nomad221's Avatar
nomad221
nomad221 is offline
That's a vband clamp. Yes, there is an oring between the turbo outlet and Y pipe. Riff Raff sells everything you're looking for. Great prices too.
Midwest beat me to it. Bob at Diesel Orings is a good guy as well.
88LX5.0H
01-17-2014 07:06 PM
pontichev
03-14-2009 05:44 PM
Rick2001
02-15-2008 10:29 AM
ron's power stroke
06-16-2007 07:01 AM
jtharvey
17
02-10-2006 01:35 AM
Quick Reply: Turbo hoses and boots
