Greasable spring shackel bolts - Ford Truck Enthusiasts Forums
Australia Chapter Join Chapter , Leader: ChunderDownUnder
Old 07-06-2013, 09:11 AM
Aussie BrianB's Avatar
Aussie BrianB Aussie BrianB is offline
Aussie BrianB has a good reputation on FTE.Aussie BrianB has a good reputation on FTE.
Question Greasable spring shackel bolts
Anyone know if greasable spring shackel bolts are available for a 2002 F250 XLT 4x4?
Old 07-21-2013, 12:01 AM
WA F250's Avatar
WA F250 WA F250 is offline
WA F250 is starting off with a positive reputation.
I too have been search for these elusive parts. I asked Clay at RR and he didn't know of any either???
Old 07-21-2013, 04:03 AM
Thats a worry, if the yanks don't got em no one is is.
Old 07-21-2013, 04:35 AM
WA F250's Avatar
Sorry Brian,
I mis read your question. I found some JC Whitney greasable shackles but I couldn't find any greasable pins to compliment them. I also wasn't too impressed by the pictures of their kit? It didn't look beefie enough (I may be wrong)
About the only thing I can think of is to get my stock pins drilled and tapped. Now I am not sure how much strength that will take away?????
Old 07-21-2013, 04:45 AM
Quote:
Originally Posted by WA F250 View Post
Sorry Brian,
Unfortunately drilling and taping isn't enough.
You would need to machine a spiral groove around the outside of
the pin to spread the grease around the inside of the bush.
These things are available for rice burner 4x4s, landrovers, jeeps and
caravans, I have a set on my van.
Puzzles me why there are none for F trucks.
Old 07-21-2013, 04:48 AM
WA F250's Avatar
If you are only after the shackle pins have a look at the JC Whitney's? I was looking for the whole package to try to keep it all a plush ride as much as possible. I am about to do my lift kit and wanted to do it all at once.
Good luck
Old 07-21-2013, 05:02 AM
Thanks mate, I'll go check out Whitneys.
Stuck shackel bolts on the front. Kendrick Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 5 05-25-2015 09:23 PM
2000 Explorer Leans Left ptwohey Explorer, Sport Trac, Mountaineer & Aviator 10 03-20-2014 11:02 AM
Help on Rear Springs & Shackels tractormanbill 1948 - 1956 F1, F100 & Larger F-Series Trucks 11 01-26-2014 10:49 AM
Rear Shackel Problem scatgo Offroad & 4x4 127 03-27-2011 10:30 AM
Rear leaf springs 1968 F100 ramtoo 1967 - 1972 F-100 & Larger F-Series Trucks 4 05-26-2005 09:21 AM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
