Parasitic Battery Drain
OK, this topic has been on my to do list for a while. For the longest time I though my Optimas just wouldn't hold a good charge anymore. It appears it is parasitic draw. This was slow with just myself, but I used vice grips to hold my meter leads to the cable and post.
I have a constant .20A draw. When I unplug fuse #14(Dome light, Courtesy lamp, Cargo Lamp, Running board lamp) it jumps to .35A for about 20 seconds then returns to .20 even though the lights are off.
The next one is one I think is the problem, #15(Stop lamp switch, GEM, PCM, 4 wheel ABS, Brake shift interlock, Cluster, PCM keep alive memory). Load goes from .20A to .03A unplugged.
What finally got me going on tracking this down is that my new Edge CTS Insight display is randomly staying lit up overnight with the key off. It seems the PCM isn't shutting off all the time.
Any idea of what to do next??
I think it is square and is a bosch style relay. The diagram is on the side if it is. The new style iso relays are the small rectangular ones. The bosch style use terminals 85 & 86 for the coil. It should have some resistance on it but not a lot. When its in your hand, terminals 30 & 87a should have continuity and 30 and 87 should not. If you power terminal 85 & ground term 86, it should then have continuity on term 30 and 87. I think the blower relay can be swapped in its place.
Another thing that could cause pcm to not power down is if the windshield leaks and wet the gem.
I have had same problem and finally bought a new Edge, as I like to use it for read-outs, not to bump power, and I had purchased the first one used.
After that the new Edge no longer lit up on its own, but I still have random problem with parasitic load that is driving me nuts. Will be fine for weeks, then I will come out and batteries are low.
I am taking another run at it later today.
Given the OP is reporting only a .2 amp draw, it will take a very long time, if the batteries are fully charged to start with. Five hours to draw down one amp, maybe 100 hours to take one battery down to 50% discharge in a 200 amp hour battery. Rough estimate only here.
