In need of some NEW brakes
It seems to have more pressure and volume.
At least it works for lifted trucks with big tires without making noise and puking its guts.
It is not a noisy, under powered, failure prone POS, like the C2.
So, are you looking for a pump, or the Hydroboost unit, or both?
Find the pump brackets from a van with the same engine as yours. (if you have somewhat stock dress)
The booster, pedal, pump and lines can come from a car or truck, I think.
I've even seen some threads where people use a '90's Astro/Safari van booster.
There's got to be hundreds of hydroboost conversion threads on this forum.
You seem to have made MANY mods to your truck.
I can't begin to say what will fit (and work) on a vehicle I've never seen.
In fact I have never done a Hydroboost conversion.
I have worked on and driven any number of vehicles equipped with it though.
It was just a suggestion, given that you complain about poor braking, want something belt driven, and have no vacuum.
I went to the pick a part today and they don't have any diesel motors to pull a hydroboost unit from.
I think the bigger problem is the bracket for the pump. With my blower, I have a large bracket that holds the PS pump, A/C compressor, and the blower. This bracket came from Vortech with the kit for the blower. I can't remove that and I don't want to cut it up as I can't get a replacement, if needed.
Charles2703
02-01-2015 01:49 PM
scooterspal
25
02-17-2012 03:50 AM
Green Streak
04-17-2010 11:43 AM
