Back up lights
Old 07-05-2013, 04:56 PM
K9sicem's Avatar
K9sicem
K9sicem is offline
Back up lights
The PO drilled two holes in the lower part of the 58. So I looked in my Dad's old parts bin and found these lights. I don't know what they are from but they filled the holes and don't look to bad.
I thought I would make back up lights. Has anyone done a back up light set up. I have a manual trans so the switch would have to be custom made. And yes thats flat purple paint....this is my wife's truck and that's what she picked out.
Old 07-05-2013, 05:39 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
^ 1949/51 Ford Passenger Car backup lamps. Were a dealer installed accessory, located on the rear body panel below the deck lid.
Note: Unless you changed them, the bulbs are #1129 6V. You'll have to find a 12V single contact bulb that is the same size to replace them with.
FoMoCo didn't offer backup lamps for trucks (Bronco's/Econolines) until 1967.
Old 07-05-2013, 06:46 PM
K9sicem's Avatar
K9sicem
K9sicem is offline
Good to know they are Ford parts. I'll change the blubs before I fab the switch. I want to make sure they work before I do the fab work.
Old 07-06-2013, 07:34 AM
Walston's Avatar
Walston
Walston is offline
I just put a toggle with an led indication on the dash, works great.
Hotrod350
05-06-2018 12:37 AM
Stevaroo01
10-06-2015 03:22 PM
dylanellis
21
12-05-2011 07:47 PM
rooster22
04-27-2010 06:09 AM
bat1965
1997 - 2003 F150
11-26-2004 11:49 PM
Quick Reply: Back up lights
