heater hose connection - Ford Truck Enthusiasts Forums
Old 07-05-2013, 03:21 PM
1981Ranger's Avatar
1981Ranger 1981Ranger is offline
1981Ranger is starting off with a positive reputation.
I have a 351m and need too now which hose connects pump to the heater core and the hose to the block to the heater core and i am kinda getting tired of the trucks heater problems
Old 07-05-2013, 04:54 PM
Franklin2's Avatar
Franklin2 Franklin2 is offline
Franklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant future
I have never worried about how they hooked up, it really doesn't matter as far as I know. These trucks do not have water valves, the water just flows through the core all the time.
Old 07-05-2013, 08:43 PM
Gary Lewis's Avatar
Gary Lewis Gary Lewis is online now
Gary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant future
Dave is right - it doesn't matter which way it flows. But, what heater problems are you having?
Old 07-05-2013, 11:16 PM
Bootlegger's Deluxe's Avatar
Bootlegger's Deluxe Bootlegger's Deluxe is offline
Bootlegger's Deluxe is starting off with a positive reputation.
being as it's summer months, i know several people who, to temporarily solve heater issues, will loop the system, making it so no coolant goes through the heater core. but, to allow us to help you better, what issues are you having, exactly?
Old 07-05-2013, 11:31 PM
1981Ranger's Avatar
Replaced second heater core and still leaking
Old 07-06-2013, 01:39 AM
joshofalltrades joshofalltrades is offline
joshofalltrades has a good reputation on FTE.joshofalltrades has a good reputation on FTE.
sounds like its time to buy a different brand of heater core
as for hose connections, if one is above the other its best to have the hose from the top port to the water pump, and the one from the bottom port to the head. otherwise there's a chance of an air pocket getting stuck in there - but i don't remember, maybe they're side by side, in which case it doesn't matter at all.
Old 07-06-2013, 07:03 AM
Gary Lewis's Avatar
There's been quite a bit of discussion on here about heater cores, but most of it has been regarding them fitting rather than leaking. If you are getting new ones that leak I would find a new source. But, there aren't very many different sources in reality.
Old 07-06-2013, 07:17 AM
Franklin2's Avatar
The heater cores are very thin and can't take much abuse from taking the hoses on and off. If you ever need to replace the hoses on a old but good heater core, always take a knife and cut them off the heater core barbs, never twist them off. It will leak every time if you twist them off, been there done that.
Old 07-06-2013, 10:00 PM
1981Ranger's Avatar
Thats exactly what i did is there one for an ac truck that you guys would recommend i really don't want to pay a mechanic 460 dollars just to do it
Old 07-06-2013, 10:16 PM
Gary Lewis's Avatar
Is it factory or dealer air?
Old 07-06-2013, 10:21 PM
1981Ranger's Avatar
Its factory
Old 07-06-2013, 10:35 PM
Gary Lewis's Avatar
Factory is the easiest. I got mine from Archion, also known in real life as Matt Vose. PM him and he can fix you up. But this thread has info specific to your truck, as mine is an 81 Ranger with factory air as well.
Old 07-07-2013, 03:58 AM
Archion's Avatar
Archion Archion is offline
Archion has a superb reputationArchion has a superb reputationArchion has a superb reputationArchion has a superb reputationArchion has a superb reputationArchion has a superb reputationArchion has a superb reputationArchion has a superb reputationArchion has a superb reputationArchion has a superb reputationArchion has a superb reputation
Unfortunately Gary I no longer work for that company, or sell auto parts for that matter...
And if your mechanic is quoting you 460 bucks to do that factory a/c heater core, he is a crook and needs to close shop.
Old 07-07-2013, 07:10 AM
Gary Lewis's Avatar
Matt - I hope the new job has an easier commute and better pay.
Heater Core Hoses: Inlet x Outlet/Return celsoglima Ranger & B-Series 7 12-16-2016 09:06 AM
installing new quick connects on heater core? 69ford99 1997 - 2003 F150 8 11-06-2013 03:12 PM
need heater hose routing diagram ken's1971 1967 - 1972 F-100 & Larger F-Series Trucks 2 10-19-2004 05:35 AM
Clogged heater core? Aeropain Aerostar 13 10-02-2004 09:42 PM
Heater control valve? elstx 1967 - 1972 F-100 & Larger F-Series Trucks 11 01-16-2004 06:20 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
