2001 F650 "Tralier Air Brake Package"(158).....W-H-A-T????? - Ford Truck Enthusiasts Forums
Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
Old 07-05-2013, 04:02 PM
vee10td vee10td is offline
vee10td is starting off with a positive reputation.
Now it's well known that on Nov.2,2001 Ford announced a Tractor Package for the F750(2002MY), but visiting Ford's media website, I came across the ordering guide for the 2001 F-650.Printed in Oct. 2000, it lists the following package(option code 158) for the 2001 F650 : Trailer Air Brake Package. Um, wouldn't this be like a factory tractor package? It included: Air & electric lines to the end of the frame, Glad hands, Trailer parking ****, and Auxiliary transmission cooler.
Old 07-05-2013, 06:08 PM
MX727's Avatar
MX727 MX727 is offline
MX727 is starting off with a positive reputation.
Air lines for a pintle hitch or other tow behind trailer. I don't read anything that implies tractor.
Old 07-06-2013, 09:28 AM
Okay, maybe I read into the "tractor" thing. So this package was basically like a tow package for the F650? Makes sense. I do want to point out something, however. In the 2001 Sourcebook section for the F650/F750 trucks they list possible uses for these vehicles. They list some of the following : dump , towing/recovery, stake, TRACTOR, beverage chassis...Ford's descriptions, not mine. I guess any F650,or F750 could be coverted into a tractor.
Old 07-08-2013, 11:31 PM
Louisville Joe Louisville Joe is offline
Louisville Joe is gaining momentum as a positive member of FTE.Louisville Joe is gaining momentum as a positive member of FTE.
I don't remember any sort of 'tractor package' available on the 2000-2002 F series medium duty trucks. I don't think they were ever offered in a short wheelbase for tractor applications. Those trucks were not much more than a limited continuation of the 1980-1998 F series medium duty chassis with a Super Duty cab and some additional diesel engine options. My company tried to buy a few of those, and the chassis options and configurations were very limited. That changed when the Blue Diamond trucks came out. They offered a lot more optional wheel bases, suspensions, and axles. I know the Blue Diamond can be configured as a tractor, even though I have never actually seen one.
Old 07-09-2013, 03:32 PM
For 2002 MY Ford listed a tractor package for the F750. It included : 10,000 lb. capacity front axle, 23,000 lb. rear axle, choice of two Cummins 5.9L ISB engines, or three CAT 3126B engines, 7-pin trailer connector and in-cab plumbing, air brakes only, available with all 33,000-lb. GVWR transmissions, 12-foot coiled electrical hose mounted to back of cab, or to frame, trailer brake control valve(Johnny Bar), rear-facing turn lamps, available in 158" wb regular cab, or 179" wb Supercab. Available options: vertical exhaust (stack), handling package. 5th wheel hitch not included in package(i.e. aftermarket). In 2000&2001 they didn't officially offer a tractor package, but 2002&2003MY F750s could be so equipped. Starting with the Blue Diamond 2004MY trucks,in the 2004 Sourcebook, it states "NOTE: All 2004 F-650/F-750 models(except Pro Loader models) will be available as either a straight truck or a tractor(the power unit of a tractor-trailer combination). Pro Loader models are only available in a straight-truck version." So the earlier tractor package was F750s only. Now we have both F650 & F750 tractor packages available.
My fault Larietpsd 2015+ F150 16 05-11-2016 02:57 PM
trailer brakes panelguy 1997 - 2003 F150 4 08-02-2014 07:18 PM
F650 V10 with Tractor Package vee10td Modular V10 (6.8l) 1 07-07-2013 10:19 AM
Overload package or airbag system? Jsgilliam 6.7L Power Stroke Diesel 15 09-12-2012 02:01 PM
Towing Package Wiring HOTFOOT 1999 to 2016 Super Duty 19 06-13-2012 01:34 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
