What year models are best for running B100 - Ford Truck Enthusiasts Forums
Old 07-05-2013, 10:44 AM
Hawkdriver69's Avatar
Hawkdriver69 Hawkdriver69 is offline
Hawkdriver69 is starting off with a positive reputation.
Looking to buy an older truck that I have the option of running B100 or possibly WVO if I want to without having to worry about clogged injectors and such. From what I have read on here people are saying Pre 95'. I was looking at 99-05 but I saw that the 6.0 would have problems with with B100. Would the 99-03 7.3 have the same problems? Just trying to figure out what would work best. I am not interested in winning any races as far as power goes and i don't care about body style. It's a ford they all look good, Just trying to figure out where I need to focus my search here. Thanks guys.
Old 07-09-2013, 12:16 PM
IABill's Avatar
IABill IABill is offline
IABill is gaining momentum as a positive member of FTE.
Wink
I have run B-100 in my 7.3 IDI 1994 & 7.3 2002 Powerstroke for years (6-7) and had no problem. You just need to keep a spare fuel filter around as 100% will clean you fuel system and push any garbage in the fuel system righe to the filter in short order when you first start using 100%.
On my 2007 6.0 have had no issues for nearly 50K mikes of burning 100% bio, But I have do not use it during cold weather IE; 40 deg or less.
And here is the reason the stuff I brew at home in colder temps will have what I call fat drop out at colder temps and plug the primary fuel filter mounted on the frame rail. My old 7.3 PS had only one fuel filter in the valley of the moter with an electric heating element and never had a problem down to about 25deg. but I did not push it any colder than that before i switched back to petro diesel.
Some other guys have had some good luck running high blends of bio in post 2007 6.4 motors. They might jump in here.
So if you are not making your own Bio, most of the stuff you can buy is pretty good quality you should not have any issues 2007 and older
Good luck!!
Old 07-10-2013, 12:39 PM
What about WMO? Anybody run it in 95 and up powerstrokes? Or can it only be safely run in the 6.9 & 7.3 IDI yr models? I know you need to mix WMO with #2 but I am curious as which diesels are the most versatile as far as types of Alt fuel.
Old 07-16-2013, 11:57 PM
timmyboy76's Avatar
timmyboy76 timmyboy76 is offline
timmyboy76 is a splendid one to beholdtimmyboy76 is a splendid one to beholdtimmyboy76 is a splendid one to beholdtimmyboy76 is a splendid one to beholdtimmyboy76 is a splendid one to beholdtimmyboy76 is a splendid one to beholdtimmyboy76 is a splendid one to behold
i thought you want to mix wmo with RUG? And for burning wvo, wmo or bio, the 99-03 7.3's have proven to last.
Old 07-20-2013, 12:19 AM
robertcoogan robertcoogan is offline
robertcoogan is starting off with a positive reputation.
huh?
Quote:
I ran B100 I made through my 2006 Ford F-250 for fourteen months and had no issues.
Old 07-20-2013, 11:33 AM
Awesome thanks for the input.
Old 07-20-2013, 02:49 PM
What about WMO?
I would stay away from it. I know regular diesel is added to thin it out, but I haven't heard anything incredibly positive about it. The viscosity is a problem, but I think that polymerization of the injectors can be a bigger issue. Why not run biodiesel and not have to worry about modifying your truck or car?
Old 08-02-2013, 03:00 PM
Lin19687 Lin19687 is offline
Lin19687 is starting off with a positive reputation.
I have been running B100 for the past couple months.
I think I will run only B50, mix it.
I have lost a huge amount of power and it is hesitating. but as soon as I added Reg 1/2 tank Diesel to 1/2 tank Bio it is running Way better,
I drive a F-350 6.0 2006
Old 08-03-2013, 11:15 AM
Rushmore X's Avatar
Rushmore X Rushmore X is offline
Rushmore X has much to be proud ofRushmore X has much to be proud ofRushmore X has much to be proud ofRushmore X has much to be proud ofRushmore X has much to be proud ofRushmore X has much to be proud ofRushmore X has much to be proud ofRushmore X has much to be proud ofRushmore X has much to be proud of
my 7.3 runs great on it...
Old 09-02-2013, 04:00 AM
Supercab Supercab is offline
Supercab has a very good reputation on FTE.Supercab has a very good reputation on FTE.Supercab has a very good reputation on FTE.Supercab has a very good reputation on FTE.
Wink
Quote:
+1 I have been running B100 in my late '99 7.3PSD for 2 years now from Glover Oil right here in town!
From what they tell me its made from Beef Tallow from "out west"
Old 09-02-2013, 10:24 AM
SkySkiJason's Avatar
SkySkiJason SkySkiJason is offline
SkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant future
There is no problem running B100 in any PSD. The fuel system can handle it just fine. Cold weather operation depends on the feedstock the B100 was made from and the gel point can vary from <30*F to >80*F. (commercial B100 is often ~40*) I would keep a sample of recent purchase in a water bottle and place outside as it starts to get cold - and start adding D2 as needed to keep it from gelling.
Many report initially changing filters, etc due to 'cleaning out the fuel system' - but none of the vehicles I have put B100 in had that problem. I recommend ANYBODY who wants to run 'alternative fuel' in a PSD install a fuel pressure gauge post-filter anyway - then you'll KNOW if/when a filter is plugging up!
Also, ALL PSD's should do the 'in-tank' mods that delete the factory in-tank mixing chamber and non-serviceable filter. Just use something like a WIX 33972 before the pump (don't use anything 'finer' than 50 mic here - 150 mic is ideal).
WMO? Bad idea. There are a few claims of 'success' running blends of WMO, RUG, Kero, etc - but they are far and few between (and their success is often reported through rose-colored glasses ). The fact is, WMO blends will produce copious amounts of toxic smoke from the tailpipe and eventually coke up the combustion chamber. Lots of engines have ended up in the scrap metal bin as a result of this 'experiment' - but very few people come back on the 'net and say they failed.... I always say 'Choose wisely - or please post pics of the carnage'.
Old 09-18-2013, 02:44 AM
speedwrench72's Avatar
speedwrench72 speedwrench72 is offline
speedwrench72 is starting off with a positive reputation.
I run virgin 0/20 full syn moter oil blended with #2 at 50/50, over 5,000 miles with no smoke, or starting problems, just up graded to zd9 glows, removed champion's, no coke on glows, if I mix 70/30 she starts hard.. but if I add 3 or 4 % RUG starts fine. stock filter and lift pump.
Old 09-19-2013, 12:36 PM
flainn's Avatar
flainn flainn is offline
flainn has a very good reputation on FTE.flainn has a very good reputation on FTE.flainn has a very good reputation on FTE.
Quote:
Sounds great ... but how on earth do you afford to do that? Lube oil is so much more expensive than pump fuel.
7.3L PIDs for 2016 - Torque Pro and others. Tugly 1999 - 2003 7.3L Power Stroke Diesel 124 Today 03:21 PM
Research Samorkand Modular V10 (6.8l) 7 02-04-2015 05:54 AM
Mallory UNILITE IGN. W/ MSD BLASTER 2 COIL. NO SPARK RANGER589 Electrical Systems/Wiring 9 06-25-2014 10:09 AM
What size wheel and tyre fits well on 56 F100 with 8.8 inch rear Aus56 1948 - 1956 F1, F100 & Larger F-Series Trucks 4 06-02-2013 05:00 AM
early 99 hub conversion ???s CuNmUdF250 1999 to 2016 Super Duty 7 01-01-2013 03:37 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
