Uh oh... First 6.0 problem - Ford Truck Enthusiasts Forums
Old 07-05-2013, 01:28 AM
jarrodh jarrodh is offline
jarrodh is starting off with a positive reputation.
hey, so the other day my truck developed a hesitation when cruising at highway speed, like a chugging feeling.. Shut it off, restarted the truck it went away.. All was well..
Now today it came back, built good boost, actually a bit to much I think(pegged my 35lb automated gauge, then some) and this time I watched my boost gauge during this and it jumped down in steps with each chugging feeling.. And when I got into it, and I built boost and lett off it has the sounds of a jake brake (puh puh puh puh) as the boost comes down, and jumps down in steps with each sound..
Wtf is goin on.. Oil press in dash reads good, temps are good.. Isn't blowing clouds of black, idles and starts perfect in the mornings..
Any ideas? Starting to kinda freak me out..
Old 07-05-2013, 01:38 AM
BLADE35's Avatar
BLADE35 BLADE35 is offline
BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.
Turbo overboost
May need clean turbo or may need a New Sensor
Got a OBDII Gauge
Old 07-05-2013, 02:32 AM
No check engine light yet.. I'll put the scanner on it tomorrow afterwork
Old 07-05-2013, 03:23 AM
Yahiko's Avatar
Yahiko Yahiko is offline
Yahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputation
Don't keep driving it. Over Boost can = Blown Head Gaskets and that leads to
BLOWN BANK ACCOUBT
Sean
Old 07-05-2013, 08:55 AM
big inch big inch is offline
big inch has a good reputation on FTE.big inch has a good reputation on FTE.big inch has a good reputation on FTE.
It sounds like the vanes in your turbo are sticking. Usually, all it takes to fix that is to remove, disassemble and clean the inside of the turbo.
Old 07-05-2013, 03:39 PM
Under normal driving the boost is fine.. Only when I put my foot in it it seems to just up..
Looks like it's time to pull it apart soon.. Rebuild turbo, install the egr delete kit. my egt, and trans temp sensors, and blue spring upgrade..
Arg.. Only got 76000 km on it
Old 07-07-2013, 11:12 PM
nboz97 nboz97 is offline
nboz97 is starting off with a positive reputation.
HELP, F350 6.0 L diesel
My 2004 F350 6.0L v8 has a weird shake when I get between 45 and 55 mph. Doesnt feel like its the tires, feel like the engine. I think I might have the #5 glo plug out. Is that it or could something else be wrong? If it is this how bad is it to drive on? Or how bad/much will it cost to change?
Thanx
John
Old 07-07-2013, 11:45 PM
BLADE35's Avatar
Quote:
Thanx
John
Glow Plug shouldn't cause shake
Need to watch FICM Voltage
Scan for DTC
get a Gauge like scangaugeII or something like
Still have an EGR Valve??Clean it in awhile??
Put fuel filters on the list
Old 07-07-2013, 11:46 PM
Snuggyworm's Avatar
Snuggyworm Snuggyworm is offline
Snuggyworm is a splendid one to beholdSnuggyworm is a splendid one to beholdSnuggyworm is a splendid one to beholdSnuggyworm is a splendid one to beholdSnuggyworm is a splendid one to beholdSnuggyworm is a splendid one to beholdSnuggyworm is a splendid one to behold
i dont think the glow plug would have major issues with the operation of the truck after it's started but i could be wrong. is the shake kinda obvious? it may be something as simple as ur brake pads even. do u have 4wd? might be the front wheel hubs or the needle bearing. we wont know until we can pinpoint it closer.
or it might be something from the engine.
Snuggyworm's Avatar
dang it. benny, u beat me to it. lol.
Old 07-07-2013, 11:52 PM
04badford 04badford is offline
04badford has a brilliant future04badford has a brilliant future04badford has a brilliant future04badford has a brilliant future04badford has a brilliant future04badford has a brilliant future04badford has a brilliant future04badford has a brilliant future04badford has a brilliant future04badford has a brilliant future04badford has a brilliant future
I would clean the EGR valve ,and MAP hose to Intake that lil hole gets clogged, do you run any fuel treatment , like diesel kleen ,howes ceatain boost? change fuel filters and drain water sep
Old 07-08-2013, 12:02 AM
The fuel filters are almost new(2 months old). I dont run any fuel treatments, should I? It really doesnt feel like the front end or alignment, I can feel it start in the gas pedal. Then it goes to the engine. As an over all the engine does have a different shake to it. Also it has a new ficm or re furbished from from last week, could it still be messed up? dunno what the other stuff is or what that small hole you were talking about is.Ill look up the EGR valve too..... btw thanks you guys either way I do appreciate it
Old 07-08-2013, 12:16 AM
the MAP is located and bolted on the heater core passengers side a flat black braket with three nuts follow the 3/8 hose to the INTAKE from there theres a nipple screwed into the intake that's the lil hole that will get plugged also the nipple.
Old 07-08-2013, 12:31 AM
BLADE35's Avatar
You really Need a Gauge at this Point
How did you determine the FICM was Bad???
Old 07-08-2013, 12:32 AM
Ok ill try both the maf sensor and clean the erg valve... thanks. Ill let you know what happens....
2004 F350 6.0 Liter Sorekneez 6.0L Power Stroke Diesel 0 10-07-2014 02:45 PM
studdering idle and worse when coming to a stop bestrada11 1999 - 2003 7.3L Power Stroke Diesel 2 08-16-2014 03:10 AM
V10 hesitation crjackson 1999 to 2016 Super Duty 22 03-02-2004 06:46 PM
V10 hesitation crjackson Excursion - King of SUVs 0 02-23-2004 08:18 PM
Tach jumping chickenmanq 1961 - 1966 F-100 & Larger F-Series Trucks 5 04-26-2002 02:17 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
