Brake lights
Old 07-08-2013, 08:55 AM
1997fordf350's Avatar
1997fordf350
1997fordf350 is offline
Brake lights
Hi guys. I'm having trouble with my brake lights. The turn signals work and normal lights work. The third brake light works too. Any thoughts.
Thanks.
Old 07-08-2013, 09:40 AM
dixie460's Avatar
dixie460
dixie460 is offline
Brake light switch? Without a schematic I can't tell, but if the flashers work (which use the same filaments as the brake lights) then your bulbs and everything else common to both are in good shape.
Old 07-08-2013, 11:09 AM
1997fordf350
Where that at. Flashers work
Old 07-08-2013, 11:21 AM
White 97 xlt's Avatar
White 97 xlt
White 97 xlt is offline
Do your 4 way flashers work?
If not, make sure the switch is in the DOWN position, up is on and it kills the brake lights to everything BUT the high mounted stop light.. (3rd brake light)
Now if this cures the brake lights check out the flasher unit on the back side of the fuse panel (up under the dash), (the one on the front is for turn signals) there is a good chance the flasher unit has gone bad and the hazards (4 ways) have been turned on at some point.
Old 07-08-2013, 01:54 PM
1997fordf350
Ok messed around with the wires an stuff. They are working now but don know for how long
mixerdrvr
1999 to 2016 Super Duty
05-26-2013 09:04 PM
breadstick
13
03-19-2012 08:32 PM
psoff
1997 - 2003 F150
09-22-2007 11:33 PM
Bob47
Aerostar
01-07-2004 08:14 PM
Runner70
1997-2006 Expedition & Navigator
06-14-2003 06:23 AM
Quick Reply: Brake lights
