Plus Size Tires
35s
I have a 2013 F250 and I needed a 2.5" leveling kit to run Toyo MT 35s. They don't rub at all. I test fitted them before the lift and they rubbed pretty bad. The wheels are 18" x 9" at an offset of -12 mm. They stick out about 2.5" from the side. I think it's cool how they stick out but I had to get fender flairs to keep the tires from throwing water and mud on the side of the truck.
If I had to do it over I would try zero or even positive offset wheels to reduce the amount they stick out. However some people say that you need negative offset to fit oversized tires unless you do a big lift.
I just drove home my new 2013 F250 platinum edition w 20" inch wheels. Would the 35's fit on here with or without a level kit? It has the FX package also which I believe raises the chassis up a little more than stock with the new shock package. if i cannot get the 35's, how big can I go wo getting a lift kit? Appreciate any help on this as I would like to do this tomorrow.
Would i have to recalibrate the speedo?
DieselBeast01
2004 - 2008 F150
23
06-06-2018 05:09 AM
TexFx4
2004 - 2008 F150
08-26-2005 07:14 AM
