is it normal for oil level to be a little low? - Ford Truck Enthusiasts Forums
2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Old 07-04-2013, 02:24 PM
jdm5630 jdm5630 is offline
jdm5630 is starting off with a positive reputation.
So I checked the oil level today and I noticed its about a quart low. I don't have any leaks. Ive been using Valvoline maxx life high mileage. Engine has 98,000 miles. its never been low like that before. Is it normal?
Old 07-04-2013, 02:30 PM
JWC 3's Avatar
JWC 3 JWC 3 is offline
JWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputation
How many miles since last oil change ? Lots of engines use a bit of oil , and if too long between changes , it will show . Ck your pcv also , that can cause oil consumption . If you are going 5k between oil changes 1 qt is not bad . If only 200 miles , that would be different .
Old 07-04-2013, 02:35 PM
Its been about 3500 miles. I usually change at 4,000
Old 07-04-2013, 02:43 PM
JWC 3's Avatar
One qt in 3500 miles is not "excessive" . But could be an issue . Ck your PCV and crank vent . Double check for leaks and do not use too thin an oil ( it will burn away faster ) . I would go ahead and change it also and start keeping a close eye on it to be safe .
Old 07-04-2013, 02:55 PM
Do you recommend switching to a 5w/30?
Old 07-04-2013, 03:05 PM
JWC 3's Avatar
My 04 calls for 5w30 . I use 10w30 in the summer and 5w30 in the winter , for the last 100k . I would see no issue going to 5w30 insted of 5w20 . Or even 10w30 if used hard or in a hot climate .
Old 07-05-2013, 11:20 AM
alwaysfords41's Avatar
alwaysfords41 alwaysfords41 is offline
alwaysfords41 is gaining momentum as a positive member of FTE.
Quote:
04 Expedition? 5.4? My manual calls for 5W-20.
Old 07-05-2013, 07:46 PM
JWC 3's Avatar
Quote:
Sorry , I should have said my 04 Mounty . I was just using the recomendations of mine as an example . I should have been more clear .
REAL need of help... kupiec20 1994.5 - 1997 7.3L Power Stroke Diesel 66 03-31-2016 12:53 PM
Engine died...No oil pressure BlackNM6.0 6.0L Power Stroke Diesel 72 10-09-2012 11:15 AM
how much oil is your 7.3 using polish dude 1999 - 2003 7.3L Power Stroke Diesel 21 02-21-2011 08:42 PM
head gasket? 91dirtydiesel Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 52 11-29-2010 09:44 PM
Whys my oil pressure drop? truckman79 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 8 08-29-2003 09:06 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
