NEW B&W Companion Slider
A couple of months ago we put down a deposit on a shiny new 5er. There were 2 things I wanted before taking delivery - a Trailair pin box and the Companion Slider. Dealer took care of the pin box and I knew the Slider was available based on an announcement from B&W.
Ordered oneup from a local dealer with free install for $300 less than the RV dealer (go figure! ). There was a backorder, I guess not too surprising for a new product, but it finally came in.
Had it installed a couple of days ago. Installation, once it was adjusted the first time, is so easy. Drop it in the hole, release the lock pin, tighten one bolt to 80 ft/lb -- that's it! No messing with U-bolts or anything. The only adjustment required was to make sure the rubber rail pads fit in the dips on the truck bed.
I'll post up some pics a little later. So far I am really impressed with the quality and fit.
Steve
I was wondering how heavy that is compared to my Reese slider. Looks like it is all one piece although you could take the head off.
I can do mine by myself with lifting one side at a time and bringing to the the tailgate.
I can also use a hand truck and lift it and rolling it to the tailgate.
Can you do any of that with the length of this unit?
I can not find the actual weight for this. The regular Companion has a shipping weight of 107 lbs. per amazon's web site and this is clearly heavier. I am going to shoot an email to the factory to find out as I should know exactly for calculating the GVW. Right now I am estimating 200 for calculation purposes.
Mod note: changed wording due to links.
No kidding!
I have a hard tonneau cover and may just pull the head off, put the tonneau back on and call the hitch my rear axle weight for winter. I rarely actually need the full bed for anything and have a 4X8 utility trailer for when I do.
Companion Slider - 5th Wheel Hitch | B & W Trailer Hitches
Installation instructions:
http://www.turnoverball.com/sites/de..._05_2013_0.pdf
I sure wish that hitch had been available when I bought the B&W Companion. I did look at the brochure and it says 2 people to remove the hitch, that base anyhow.
For a comparison in size (head appears the same).
And for customer service - you can't beat B&W. I stripped a U-bolt thread when a Nyloc insert broke so I gave them a call asking the price and delivery. No charge, sent to my home within 3 days via FedEx.
