Disc bearings - Ford Truck Enthusiasts Forums
Disc bearings
Old 07-03-2013, 10:20 PM
1oldtimer's Avatar
1oldtimer 1oldtimer is offline
1oldtimer is gaining momentum as a positive member of FTE.
Disc bearings
I have a disc brake kit on my panel, it's the 80's/90's f150 disc. The seal and inner bearing are for the f150 but the outer bearing doesn't have any markings. The f150 outer bearing is too big for the spindle..........anyone have a part number or application for the outer bearing. I'm going to hit the catalog armed with calipers if I can't find it on the internet.
Old 07-03-2013, 10:54 PM
perks56's Avatar
perks56 perks56 is offline
perks56 is starting off with a positive reputation.
Spindle bearing
1oldtimer,
If your truck has a typical disc brake kit installed it may be the same as the one I installed on my 56 F100.
Rotors - 73-93 F100/F150 2wd
Calipers - 71-76 Chev-Impala,Belair,Biscayne
Buick - Electra,Lesabre,Roadmaster,Wildcat
Pontiac - Bonneville,Catalina
Oldsmobile - 88,98,Delta 88,Regency 98
Bearings and seals - Outer A2/Set2 used on 64-77 GM Intermediate cars,Camaro,Firebird,Chevelle,Monte Carlo etc.
- InnerA13/Set13 Standard inner bearing used in Ford Rotor
- Seal - National 4148 - standard seal used in Ford Rotor
Good luck, I hope this helps
Perks56
Old 07-03-2013, 10:58 PM
1oldtimer's Avatar
That's it.
Thanks Perks.
I was looking at my Timken catalog, set is also 57-66 F100. Damn I found USA made Timkens also....well back on the hunt for some set 2.
87' Wheel Bearing Question MThrasher16 1987 - 1996 F150 & Larger F-Series Trucks 5 01-24-2011 05:09 PM
replacing the outer wheel bearings 74redone 2004 - 2008 F150 24 11-11-2010 12:04 AM
rear axle wear on 98 f150 h20fella 1997 - 2003 F150 3 07-20-2010 10:10 PM
outer axle shafts 2classics 1966 - 1977 Early Broncos 4 03-30-2006 12:31 AM
New findings on 61-63 disc breaks!!!! TMAXXjj 1961 - 1966 F-100 & Larger F-Series Trucks 10 04-12-2002 06:18 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
