05 F250 6.0 rough running - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 07-03-2013, 02:43 PM
Razorback Jeff Razorback Jeff is offline
Razorback Jeff is starting off with a positive reputation.
Exclamation 05 F250 6.0 rough running
At 154k I'm on a third set of injectors. Most recent issue was loss of oil pressure. Mechanic replaced IPR, IPC, Stand pipes and a fitting on the HPOP(the cause of oil pressure loss). While he had it apart, also did an EGR delete.
Ran great for 4 days and then started noticing a bit of rough idle intermittently.
The problem has progressed. He rode w/ me with scan tool attached and only errors are mass airflow and non correlating intake air temp. The problem comes and goes, but seems to be worse when warm. Any thoughts would be appreciated!
Old 07-03-2013, 07:21 PM
Dan Thorpe Dan Thorpe is offline
Dan Thorpe is starting off with a positive reputation.
Just a thought... VGT sticking? Probably wouldn't cause idling issues but one never knows!
Old 07-04-2013, 03:27 AM
Yahiko's Avatar
Yahiko Yahiko is online now
Yahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputation
First off. Welcome to FTE.
The better place for you questions would be in the
6.0L Power Stroke Diesel - Ford Truck Enthusiasts Forums
You should get some good info. One good place to start is the tech folder.
Sean
Loss of power with my 7.3l, rough running HELP! kexchange 1999 - 2003 7.3L Power Stroke Diesel 23 11-07-2016 10:37 AM
No Start 2007 F350 6.0 dirtman48 6.0L Power Stroke Diesel 16 03-20-2016 09:19 PM
6.0 Loss of low oil pump pressure when at operating temp. bpete 6.0L Power Stroke Diesel 1 07-16-2014 06:28 PM
What causes low oil pressure? Number21 6.0L Power Stroke Diesel 25 05-14-2014 03:52 PM
'99 Ranger 4.0 Runs Rough @ Start up 1975 F250 Highboy Ranger & B-Series 1 06-06-2013 08:48 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
