92 7.3 diesel F250 - Loud Knock- White Smoke
Just about a 1/2 mile from home, suddenly the truck makes a very loud rapid knocking, and pours white smoke from the exhaust.
This seemingly came from out of no-where.
It's a 92 f250 7.3 with 250,600 miles.
Any suggestions on what could be going on, and/or steps of how to self diagnose?
Thanks.
Thanks.
Received 3,102 Likes
on
Do you know if the coolant has been treated with SCA additive and for how long? 250K on a 7.3L IDI without SCA additive in the coolant it might be cavitation (hole rusted though water passage into the cylinder).
It would explain the white smoke (coolant burning off in exhaust), the knocking (damaged rod/bearings from vapor lock), water in oil (running down past the rings), and the abruptness of the onset.
No there haven't been any additives in the coolant.
What should I do? I have some mechanical skills- though i've never taken apart the engine. I'm up for it-
Is there any way to determine if it could be the oil cooler, since that seems a lot easier? Or would there not be knocking if it was the oil cooler?
on
not true. i know of at least 5 that never had any additives added to the coolant other than what was put in at the factory, and they all have over 400,000 miles on them.
an oil cooler is easy to take off.
the noise in the bottom end is probably a rod knock from the water in the oil, or a hole in a piston.
it sounds like you may be looking at replacing the engine.
on
vapor lock is a condition where the gasoline in the carburetor turns from liquid to vapor because of high heat. so that is something you will not see in a diesel.
the connecting rods go from the pistons to the crankshaft, the bearings are on the crankshaft in the rod connection.
the fact that you have oil and coolant pouring out of the exhaust tells me that engine is most likely toast.
on
on
