2300 2bbl carb. - Ford Truck Enthusiasts Forums
2300 2bbl carb.
Old 07-03-2013, 01:58 PM
Gregxlt's Avatar
Gregxlt Gregxlt is offline
Gregxlt is starting off with a positive reputation.
2300 2bbl carb.
I have a holley 2 bbl 2300 list #2011, tag BBT 0AA F, I am rebuilding it now, anyone know if there is a ball bearing under the accelerating discharge needle? My shop manual doesn't mention or show one, but the rebuild kit has one and shows one in the diagram. rebuild kit diagram is vague and for different models anyway.
Old 07-03-2013, 03:47 PM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
Originally Posted by Gregxlt View Post
I have a holley 2 bbl 2300 list #2011, tag BBT0AA , I am rebuilding it now, anyone know if there is a ball bearing under the accelerating discharge needle? My shop manual doesn't mention or show one, but the rebuild kit has one and shows one in the diagram. rebuild kit diagram is vague and for different models anyway.
BBT0AA = 1957/63 Ford Truck Parts Catalog, Carburetor Parts List # 95.15E
No ball shown in pic of carb (discharge needle), nor listed in parts list. I can't post a pic of the carb until 7/5/2013.
Present catalog on bound paper, ordered CD version from hipoparts.com, should be here by Friday.
Old 07-03-2013, 03:50 PM
hiball3985's Avatar
hiball3985 hiball3985 is online now
hiball3985 is gaining momentum as a positive member of FTE.hiball3985 is gaining momentum as a positive member of FTE.
Yes, there should be a check ball in there. I've never seen one without. It keeps the fuel from draining back.
Old 07-03-2013, 08:14 PM
Gregxlt's Avatar
This one did not have one from the beginning and the manual does not mention or show one. I re-read the shop manual twice now to make sure I was not missing something. As a matter of fact the accelerator needle housing is milled to the shape of the needle (cone), there isn't anywhere for a ball bearing to go on this model carb. The rebuild kit is for many models, so I wasn't relying on the illustrated parts break down they provide. Their picture showed more component than my carb had anyway. I'm thinking it doesn't get one.
Old 07-03-2013, 09:32 PM
hiball3985's Avatar
I guess if it's milled to the shape of the needle, that model doesn't use one. Most I have seen use a ball with a needle weight.
Old 07-09-2013, 12:39 PM
Gregxlt's Avatar
Yeah, found out that my style carb. uses the needle instead of the check ball and weight. See reassembly step 3 note 1.
http://chicagocarburetor.com/pdf/Ins...olley_2300.pdf
4R70W - is it an easy rebulid? BEAL73 Clutch, Transmission, Differential, Axle & Transfer Case 22 12-09-2016 06:19 PM
End of my rope? big job Large Truck 0 04-16-2015 06:18 AM
Vacuum line diagram swampthang 1973 - 1979 F-100 & Larger F-Series Trucks 3 02-27-2013 06:29 PM
Holley carb ID & pump recommendation sammycooks 1961 - 1966 F-100 & Larger F-Series Trucks 1 03-05-2010 12:54 PM
2 bbl carb on '77 300? bluegrasmtns Ford Inline Six, 200, 250, 4.9L / 300 4 02-01-2009 08:32 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
