51 F1 idle and acceleration issues - Ford Truck Enthusiasts Forums
Old 07-03-2013, 01:51 PM
Huskersteel Huskersteel is offline
Huskersteel is starting off with a positive reputation.
I have a 51 F1 flathead V8 and I'm having issues with the engine bogging down with acceleration. I had the carb overhauled within the last six months and the truck was running smoothly. It is an around town driver and doesn't get too much action on the road. About three weeks ago I took it out on the highway and had her up to 50 mph or so. She backfired a few times but other than that ran great. There is always some hesitation when stepping on the foot feet. I have played around with the acceleration pump. Having it in the summer, regular and winter holes. That doesn't seem to be the issue. The fuel is fine as I added some Stabil when I filled the tank last winter. The motor runs fine cold but when it gets up to temp is when the issue of bogging down comes about.Thanks for reading. Any and all information will be helpful.
Old 07-03-2013, 02:05 PM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is online now
postin' fool
ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.
Verify the accel pump is actually providing a solid squirt from both nozzles. Check float level too.
Old 07-03-2013, 05:28 PM
tinman52's Avatar
tinman52 tinman52 is offline
Welder User
tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.
Look for vacuum leaks. Also check timing and condition of the points.
Old 07-03-2013, 06:29 PM
FortyNiner's Avatar
FortyNiner FortyNiner is online now
FortyNiner is a splendid one to beholdFortyNiner is a splendid one to beholdFortyNiner is a splendid one to beholdFortyNiner is a splendid one to beholdFortyNiner is a splendid one to beholdFortyNiner is a splendid one to beholdFortyNiner is a splendid one to behold
Quote:
I second this. Don't forget the condensor.
Bogs down on acceleration spocky1187 6.0L Power Stroke Diesel 9 01-25-2014 08:04 PM
Help.. Acceleration problems. 5.4 2000 sprintn 1999 to 2016 Super Duty 6 12-07-2010 12:05 PM
Here are the symptoms... geodiggr 1987 - 1996 F150 & Larger F-Series Trucks 7 08-31-2009 01:34 PM
Acceleration problems FTK560 4 Cylinder Engines 2 08-20-2004 11:08 PM
No power in hot weather, O2 sensor? 95xltmud Performance & General Engine Building 5 04-22-2002 07:51 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
