fender support rod - Ford Truck Enthusiasts Forums
fender support rod
Old 07-03-2013, 11:36 AM
lilrobo's Avatar
lilrobo lilrobo is offline
lilrobo is starting off with a positive reputation.
fender support rod
on a 53 f100 are the fender support rods needed ,, i am getting ready to install a brake booster on firewall and i think i might have to move one
thanks
Old 07-03-2013, 01:47 PM
raytasch's Avatar
raytasch raytasch is online now
Old guy with old toys
raytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant future
I've seen trucks running without those braces.
Old 07-03-2013, 03:10 PM
AXracer's Avatar
AXracer AXracer is offline
AXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud of
Those braces are essential to the front end alignment and hood operation. Trust me, Ford didn't put an unnecessary piece of metal or extra bolt into their trucks. See my front sheet metal alignment procedure:
http://www.ford-trucks.com/forums/72...ling-me-2.html
Old 07-03-2013, 04:00 PM
lilrobo's Avatar
wow thats not good to hear,, my boost setup will be here on fri and i know its going to be in the way ,, one of them is anyway ......so now what ??
thanks
Old 07-03-2013, 05:39 PM
raerjim's Avatar
raerjim raerjim is offline
raerjim is gaining momentum as a positive member of FTE.
Perhaps you can just relocate the firewall end. Up or to one side.
Old 07-03-2013, 06:10 PM
Jag Red 54's Avatar
Jag Red 54 Jag Red 54 is offline
Jag Red 54 has a very good reputation on FTE.Jag Red 54 has a very good reputation on FTE.Jag Red 54 has a very good reputation on FTE.
What if you made the rod longer and moved the attachment point closer to the middle? That seems liker the easiest, cheapest way to go. Jag
Old 07-03-2013, 10:08 PM
AXracer's Avatar
I have the same issue. I've decided to make a C shaped flat metal bar (curved on the flat) to attach to the firewall bracket, go around the booster and connect to the shortened rod on the driver's side.
Old 07-03-2013, 10:21 PM
lilrobo's Avatar
post some pics when you get it ,, i need to learn how adjust mine,, i know no one has ever done it after all these years
thanks
Old 07-03-2013, 10:25 PM
AXracer's Avatar
It will be a while before I get ready to put the front sheetmetal back on.
Old 07-03-2013, 10:55 PM
CharlieLed's Avatar
CharlieLed CharlieLed is offline
CharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud of
Those rods are necessary because the cab and front sheetmetal is all mounted on rubber isolators...the rods add rigidity in a free-floating system. I mounted my radiator core support rigidly to the frame and eliminated the need for the rods.
Old 07-04-2013, 07:24 AM
lilrobo's Avatar
well there has got to be a way to install the brake booster,, or they would not make them ?? , i guess do a horse shoe piece of metal around the booster and have the rod to connect to that ,, it will look stupid but it will work ??
Front Fender Support Rods from Cowl to Fender ulev1st 1948 - 1956 F1, F100 & Larger F-Series Trucks 6 01-27-2014 04:57 AM
67 radiator support 18c 1967 - 1972 F-100 & Larger F-Series Trucks 1 04-23-2012 07:20 PM
Any tips to remove grill shell and rad support? nsaikia 1973 - 1979 F-100 & Larger F-Series Trucks 17 04-09-2007 10:34 AM
56 F100 Sheet Metal Assembly Sequence? rchassie Paint & Bodywork 6 03-18-2003 05:33 PM
53 Fender Support Rods fatfenders 1948 - 1956 F1, F100 & Larger F-Series Trucks 31 01-26-2003 05:45 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
