New sheetmetal for our trucks? - Ford Truck Enthusiasts Forums
Old 07-03-2013, 11:22 AM
Rimrock F1's Avatar
Rimrock F1 Rimrock F1 is online now
Rimrock F1 has much to be proud ofRimrock F1 has much to be proud ofRimrock F1 has much to be proud ofRimrock F1 has much to be proud ofRimrock F1 has much to be proud ofRimrock F1 has much to be proud ofRimrock F1 has much to be proud ofRimrock F1 has much to be proud of
This is a link to a article about a new "stamping" method Ford developed to form sheet metal. Sounds like once it makes it to market you could form any piece of sheet metal you wanted with just programming, no dies! Could enable making replacement parts for older vehicles very cheap.
Ford invents new stamping technology | The Detroit News
Old 07-03-2013, 11:37 AM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is online now
postin' fool
ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.
Very interesting... But I wonder what the gauge limitations are?
Old 07-03-2013, 01:06 PM
Harrier's Avatar
Harrier Harrier is online now
Harrier has much to be proud ofHarrier has much to be proud ofHarrier has much to be proud ofHarrier has much to be proud ofHarrier has much to be proud ofHarrier has much to be proud ofHarrier has much to be proud ofHarrier has much to be proud ofHarrier has much to be proud of
It will be interesting to see what happens with this technology. It will probably be many years before it gets down to folk like us.
Old 07-03-2013, 01:52 PM
AXracer's Avatar
AXracer AXracer is offline
AXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud of
In the scheme of things fabbing a one of a kind part in a couple of days without the need for dies is very cheap for someone like Ford for prototyping, but tying up a very expensive machine (I doubt the machine is cheap!) for a couple days is still going to be an expensive part to produce, and then add retail markup on top, you are probably looking at a few thousand dollar fender, and it may be that a fender is still too complex a shape to reproduce this way.
Old 07-03-2013, 02:04 PM
Harrier's Avatar
Good point AX, it is saving Ford a ton of money on concept cars, but that is still way out of our range of money thinking.
Old 07-03-2013, 02:24 PM
Rimrock F1's Avatar
True, it will probably be expensive but. Look how fast 3D printers have come down in price and even at several hundred thousand dollars it would be equivalent to a couple sets of dies and the hydraulic press. So a large parts supplier invests a half million to get set up, after he scans or otherwise gets specs for parts he could be producing parts for all different makes both old and newer. You could produce small batches of parts and then produce more as needed all without large investments in dies and the storage space for them.
Old 07-03-2013, 03:58 PM
Rimrock F1's Avatar
Old 07-03-2013, 07:04 PM
bobj49f2's Avatar
bobj49f2 bobj49f2 is offline
bobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud of
Very cool. I have a customer who is a Fanac robot dealer and I do a lot of work with them. I sent him the link but he's probably already seen it. Maybe sometime in the near future I'll be working with him on a system like this.
Old 07-03-2013, 08:58 PM
AXracer's Avatar
Interesting idea, but very restricted in what it can form. It's a two axis forming tool, basically much like a tiny english wheel, and like the english wheel it can only stretch, it cannot shrink or gather to form a part that curves or folds back on itself, basically it can only make relatively shallow bowl like forms. You could simulate it's capabilities by clamping a sheet of HD aluminum foil between two open frames then use a ball point pen to slowly emboss a shape into the foil. No matter how slowly you work eventually you will work harden the metal to the point where it stops being able to be formed or stretch it so thin it will tear. Metalsmiths ave been using a similar process to embellish sheet metal in everything from jewelry to armor to metal clad church doors to silverware since early history. When done by hand the metal is adhered face down to the surface of a bowl of pitch, and various blunt punches are used to selectively drive the metal into the pitch in a process called repousse. ( rep poo say)
http://www.google.com/url?sa=i&rct=j...72988048972596
Old 07-04-2013, 08:09 AM
mustangmike6996's Avatar
mustangmike6996 mustangmike6996 is offline
mustangmike6996 has a good reputation on FTE.mustangmike6996 has a good reputation on FTE.
pretty cool idea. hopefully it makes its way to the aftermarket and then to our trucks. in a hurry
All-New Aluminum Raptor May Debut in Detroit Next Month edtahaney 2010 - 2014 Ford SVT F150 Raptor 2 12-12-2014 06:59 PM
Seat testers joegeds 2015+ F150 2 02-18-2014 11:36 AM
Ford makes $10,000 per truck sold? joegeds 2009 - 2014 F150 13 02-16-2014 08:10 AM
2015 F150 Shadowrider123 1961 - 1966 F-100 & Larger F-Series Trucks 0 01-13-2014 11:45 PM
Steering flaw investigation Movingsolution 1999 to 2016 Super Duty 0 05-13-2013 11:56 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
