No cold air blows only Heat
Yep, leak somewheres..... you can get the freon with the dye in it, that works good to find leaks. I have used it many times and with good success
FYI - since this is in the Excursion forum - Don't forget about the Rear A/C lines.
These crack and leak, and my need to be replaced as well.
Had to fix mine last year. O`rielly had both sets (of Motocraft) line replacements for under $600. But if the system has a cracked line and been exposed - it's going to be a bit of a hefty repair bill.
on
If blowing " heat " out the front you may have a blend door issue . If no cool air at rear , you may be low on referigerant . So... sounds like you may have more than one issue . Start with an AC pressure test first ( as stated above ). And go from there . You can be low on referigerant and blow different temps , front to rear , side to side . So start there first . Good Luck !
Good idea on the blend door. I had a expedition they had to recalibrate the blend door temp since it was adjustable temp by the push buttons...... they truck never did have good AC..... I had a heater core replaced and the mechanic forgot to recalibrate the blend door, after he did it had great heat and AC.
on
If the AC compressor kicks on when in and AC mode, the AC system is not the culprit. In this case the most likely suspect is a vacuume leak usually caused by the ESOF (electronic shift on the fly) hub system that uses the same vacuume line for the front hub engagement as the dash vent box. Look at the hoses(assuming it is 4x4) from the top of the frame rail by the front shocks, to the top of the steering knuckle on the front axle. If theyre cracked, there is your issue.
Problem can also be on the blend door mechanism. Unless, just being simple here, the **** is broken on the inside and dosent turn the spindle. Pull the **** straight out and check it out too.
nymets78
12-16-2004 04:58 PM
