Looking for high-end water pump - Ford Truck Enthusiasts Forums
Old 07-03-2013, 08:28 AM
bkbauer1955 bkbauer1955 is offline
bkbauer1955 is starting off with a positive reputation.
Looking for options on water pump for 1956 ford 312 (in my f350) - looking for high flow, or billet, or aluminum -- any links or ideas /.?
Old 07-03-2013, 04:32 PM
charliemccraney charliemccraney is offline
charliemccraney is gaining momentum as a positive member of FTE.charliemccraney is gaining momentum as a positive member of FTE.
I'm not sure if the aluminum pumps are still available.
Try FORD Y
It will be a pump with car dimensions which will require a matching car pulley.
If it will be used primarily for drag racing or local car shows, you can try Ted Eaton for an electric version.
Eaton Balancing | www.eatonbalancing.com
A stock pump should cool a stock or even modified Y well enough. Do you have a cooling problem or simply want some bling?
Old 08-02-2013, 01:39 AM
chetspencer's Avatar
chetspencer chetspencer is offline
chetspencer is gaining momentum as a positive member of FTE.
I just got one from NAPA, working great. Lifetime warranty. Make sure you get the correct shaft size. 3/4" or 5/8".
Old 08-22-2013, 07:07 AM
The Horvaths The Horvaths is offline
The Horvaths has a good reputation on FTE.The Horvaths has a good reputation on FTE.The Horvaths has a good reputation on FTE.
Quote:
Part number? High-mount fan version?
Old 08-22-2013, 08:14 AM
Quote:
Sorry don't have it handy, but you need to make sure and check to see what size shaft you have now or the pulley won't fit.
Y Block Water Pump stockcar nut 1948 - 1956 F1, F100 & Larger F-Series Trucks 31 10-24-2016 02:59 PM
77 F150 4x4 351M Water pump high volume or standard? wjbedell 1973 - 1979 F-100 & Larger F-Series Trucks 4 05-29-2015 09:12 PM
FlowKooler Nod Cooling, Heating, Ventilation & A/C 3 12-27-2014 07:15 PM
Counterclockwise 390 water pump arcticatdan FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 8 01-31-2014 11:04 AM
Anybody know where to get a water pump bearing & seal? bruno2 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 5 11-07-2013 05:43 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
