Sway bar on mustang II - Ford Truck Enthusiasts Forums
Old 07-03-2013, 01:49 AM
jrockdiddy's Avatar
jrockdiddy jrockdiddy is offline
jrockdiddy has a great reputation on FTE.jrockdiddy has a great reputation on FTE.jrockdiddy has a great reputation on FTE.jrockdiddy has a great reputation on FTE.jrockdiddy has a great reputation on FTE.jrockdiddy has a great reputation on FTE.
I see people on here with sway bars on there ifs. Just curious if I will need one in the future. I have heidts crossmember with stock mustang II upper and lower control arms. I already installed strut rods. Here's some pics. Where would I install the sway bar if I needed one?
Old 07-03-2013, 08:15 AM
Gicknordon's Avatar
Gicknordon Gicknordon is online now
Gicknordon is a name known to allGicknordon is a name known to allGicknordon is a name known to allGicknordon is a name known to allGicknordon is a name known to allGicknordon is a name known to all
Yes you will need a sway bar. Im planning on using this one.
Total Cost Involved Mustang II Performance Front Sway Bar Kit
It mounts on the back of the crossmember and then you just need to add mounts on the lower arms. Its the same type that tci includes in their hub o hub kit.
Old 07-03-2013, 08:29 AM
sdetweil's Avatar
sdetweil sdetweil is offline
sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.
make sure you don't need to use the cross member notch on the rear of the cross member for oil pan clearance.. the sway bar will interfere with that..
Old 07-03-2013, 04:45 PM
jrockdiddy's Avatar
Do I put on the sway bar after an alignment or can I do it now?
Old 07-03-2013, 04:58 PM
ZOOT's Avatar
ZOOT ZOOT is offline
ZOOT has a good reputation on FTE.ZOOT has a good reputation on FTE.
I'm pretty sure you can do it now. The alignment involves the upper a arm and the toe bar from the rack. Hope I'm not "steering" you in the wrong direction. Pun intended. Ax will be along to correct me I'm sure.
Old 07-03-2013, 05:00 PM
Gicknordon's Avatar
Yeah the bottom arm doesnt really get affected by alignment. The bar should be level though.
Old 07-03-2013, 06:53 PM
jrockdiddy's Avatar
I'm kinda confused. What is the sway bar gonna do that the strut rod's don't? My strut rods connect the lower control arms to the frame to keep rigid
Old 07-03-2013, 08:00 PM
old_dan's Avatar
old_dan old_dan is offline
old_dan has a great reputation on FTE.old_dan has a great reputation on FTE.old_dan has a great reputation on FTE.old_dan has a great reputation on FTE.old_dan has a great reputation on FTE.
I am running a Fatman Fabrications MII IFS without a sway bar. The guys at Fatman call it "optional". The idea is to prevent body roll without significantly increasing the spring rate of the suspension.
So far, I'm thinking that I may add one, but the ride is so good as it is that I'm in no rush to do that.
Dan
Old 07-03-2013, 09:59 PM
AXracer's Avatar
AXracer AXracer is offline
AXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud of
All IFS will benefit from a sway bar. Strut rods just resist the lower control arm being forced back when you hit a pothole, RR track etc. The sway bar resists body roll and transfers weight to the inside wheel in the middle of a turn, no overlap of function. without a sway bar the nose heavy pickup is going to understeer/plow badly and feel like it's going to tip over when going around a curve at speed. whether or not you need one depends on how fast you drive.
Old 07-04-2013, 12:17 AM
jrockdiddy's Avatar
Well said axracer. Even I can understand that!!
Build thread-55 jrockdiddy 1948 - 1956 F1, F100 & Larger F-Series Trucks 210 02-16-2017 02:20 AM
Dolphin gauges water temp sensor jrockdiddy 1948 - 1956 F1, F100 & Larger F-Series Trucks 16 09-17-2014 11:43 PM
Ididit column Dash mount ideas-pics jrockdiddy 1948 - 1956 F1, F100 & Larger F-Series Trucks 21 05-24-2014 05:18 PM
Front fender repair? Salvageable? jrockdiddy 1948 - 1956 F1, F100 & Larger F-Series Trucks 16 10-30-2013 04:14 PM
Frame mounted brake booster jrockdiddy 1948 - 1956 F1, F100 & Larger F-Series Trucks 18 07-14-2013 02:52 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
