How to seperate the intake from exhaust manifold flathead 6 226 254 - Ford Truck Enthusiasts Forums
Old 07-03-2013, 01:02 AM
jmadsen's Avatar
jmadsen jmadsen is online now
jmadsen is a name known to alljmadsen is a name known to alljmadsen is a name known to alljmadsen is a name known to alljmadsen is a name known to alljmadsen is a name known to all
I need some tips on separating the manifold. I've soaked the bolts with ATF/Acetone mix, tapped lightly on the intake and tried tapping a small flathead screwdriver in between the two in the gasket material but they seem very happy together.
The intake is broke but the exhaust is good, so I'm trying to be careful to save the exhaust manifold. they always seem to be broke so I'm hoping I can sell this thing, assuming I can get them apart. I also thought about leaving them together and letting the new owner deal with it but it ads a lot of weight.
thanks for any ideas on this.
Old 07-03-2013, 01:47 AM
truckdog62563's Avatar
truckdog62563 truckdog62563 is online now
truckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud of
Josh - I don't think there are any quick solutions. I did the same on my 215 manifolds over a span of months. Soaking, tapping, and mild heat are the only means I know of to get them apart. Stu
Old 07-03-2013, 09:44 AM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is offline
postin' fool
ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.
Can you stick a rosebud down in the carb opening and heat the bottom of the intake plenum?
Old 07-03-2013, 09:48 AM
raytasch's Avatar
raytasch raytasch is online now
Old guy with old toys
raytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant future
Perhaps the electrolysis tank. The manifolds will not rust any additional while in the tank. I've successfully pulled rust from the seams of sheetmetal but never tried it on cast.
Old 07-03-2013, 09:53 AM
Be careful with the gas wrench. Too much heat and you can ruin them, ask me how I know. Stu
FIXED Ford 4.9 300 cid Exhaust Manifold Leak at Head FIXED Econoline Bronco REMFLEX GASKET cordts 1968-2013 Full Size Vans 8 06-28-2015 06:33 PM
Considering removing 2.9L engine Josh S Ranger & B-Series 15 05-14-2015 07:59 AM
1951 239 flathead exhaust manifold kciv00 1948 - 1956 F1, F100 & Larger F-Series Trucks 10 10-01-2014 10:19 PM
52 six cylinder manifolds questions abe 1948 - 1956 F1, F100 & Larger F-Series Trucks 7 09-07-2014 09:04 PM
Exhaust manifold tap size?? GaMachinist 1973 - 1979 F-100 & Larger F-Series Trucks 1 11-19-2013 12:29 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
