Truck dying in the middle of the road - Ford Truck Enthusiasts Forums
Old 07-02-2013, 10:46 PM
aaroncmears aaroncmears is offline
aaroncmears is starting off with a positive reputation.
Hey! I've kinda encountered a problem... Sometimes while I'm driving along, my 1988 F-150 just dies and won't start back up in the middle of the road. I try putting the clutch in and giving it more gas as it dies, but that doesn't seem to do anything. It also doesn't start immediately after. It'll turn, but not fire. I have to wait 20-30 mins, then the truck will start back up and I can usually get back home. I'm gonna put my guess as fuel pump? But if so, which one? And if not, then what's the problem? Anything helps, thanks!
Old 07-02-2013, 11:07 PM
BruteFord BruteFord is offline
BruteFord has much to be proud ofBruteFord has much to be proud ofBruteFord has much to be proud ofBruteFord has much to be proud ofBruteFord has much to be proud ofBruteFord has much to be proud ofBruteFord has much to be proud ofBruteFord has much to be proud of
An issue like that screams at me ignition module. They tend to cut out when hot and not work till cooled down. Fuel pressure is easy to check, and so is spark if you can get stopped safely. Good luck that is of course the worse part, when it happens.
If your up to it ignition modules are rather cost effective and not so hard to change out for good measure.
Old 07-03-2013, 12:08 PM
Greasemonkey93 Greasemonkey93 is offline
Greasemonkey93 is starting off with a positive reputation.
i have had the same problem with my 5.0 auto. stumbles and dies then I have to wait. pardon my highjacking but I cant find any other info that would help me fix this. been through icm, pip sensor, new plugs and wires, new dist. cap. basically almost everything
Old 07-03-2013, 12:24 PM
Conanski's Avatar
Conanski Conanski is online now
Conanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud of
Quote:
Maybe try moving to the side of the road.
In all seriousness that sounds like a classic TFI ignition module problem.. that's the module on the side of the distributor. Go to a junkyard and get one from another truck to try out. you'll need a 7/32s thinwall socket to get the bolts out of the module and you may have to remove the distributor from the motor to get at it so you'll need to know how to reseat it properly to get correct timing.
Old 07-07-2013, 08:00 PM
Thanks for the suggestions, everyone. I did some more research, and it's probably the ignition module. I'm headed to the junkyard tomorrow to pick up a new one, so let's hope for the best! Thanks again!
77 Ford F150 dies while driving chrisldunn 1973 - 1979 F-100 & Larger F-Series Trucks 11 01-27-2015 07:21 AM
O2 Harley f150 trouble Fbox71 Modular V8 (4.6L, 5.4L) 2 03-19-2013 10:19 PM
Another "truck dies when switching tanks" thread... drilling4gold 1987 - 1996 F150 & Larger F-Series Trucks 3 07-16-2012 11:22 PM
Engine dying with chip RocknXJ 1994.5 - 1997 7.3L Power Stroke Diesel 4 08-26-2007 02:34 PM
Had a Problem for Years irishguyincc Ranger & B-Series 14 06-15-2005 02:08 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
