Fast idle choke adjustment
I just put a new carb on my 360fe (Autoline= 2100 motorcraft) and can't figure out the fast idle setting on the choke. I know, how sad is that, such a simple design but its kicking my butt Even though its summer out right now with the cold spell its getting down in the low 60's at night. I've always wanted to get the truck set where I could push the gas pedal down once and have the truck start and warm up for me so I wouldn't have to sit in a cold truck and jack with the throttle for 5 minutes just to get it to idle in the winter.
This is how I've try to adjust the fast idle so far. With a cold engine off turn the choke thermostat back until the choke is almost closed just enough space to let some air get threw. Then try to turn the screw on the back of choke to set the throttle to a fast idle about 1200 rpm when engine starts. The problem is the truck wont start unless I pump the gas a couple times and give it a few blips of throttle after start to get it going. By that time the fast idle has already released itself and I'm back on normal hot idle. What am I over looking guys? Truck seems to be alittle cold natured and acts like it needs alittle choke for the first few minutes of start up.
The fast idle adjustment screw rides on a cam. When you push throttle to floor choke closes and the cam rotates and engages the fast idle. The cam should stay rotated until the engine heats and the choke opens. Then when you punch it the cam drops and you go back to normal idle. As long as you're still choked you should be able to pump the peddal and not affect the fast idle.
march's description is 100% accurate. Please read the following description with regard to setting up the fast idle linkage:
https://www.ford-trucks.com/forums/7...ml#post6422219
fmc400, could you look at my problem? I know it's a different setup but I'm totally stumped!!
I put a video over in the carb/fuel board. I haven't gotten the help that I need, though.
https://www.ford-trucks.com/forums/1...t-setting.html
A 2100-series carburetor should have the choke pulloff mounted vertically, behind the throat of the carburetor. A 2150-series carburetor should have the pulloff mounted horizontally, on the passenger side of the carburetor. The concept is the same in either case. The pulloff is a crucial piece of setting up the carburetor properly.
okie72
01-29-2014 09:32 PM
f100help
10-09-2010 03:37 PM
