banks turbo questions
Received 3,090 Likes
on
Turning up the fuel screw will spool it up more but it will also melt your pistons if you're not careful. Don't go there without a pyrometer. Also, pushing a sidewinder really hard will make more pressure on the gage, but it will be out of its favorable range on the compressor efficiency map, so those psi will mostly be from heat, not density. This won't do much for you except skyrocket your egt's and upper cylinder temperatures. Even though you ~can squeeze about 20 psi out of a Banks by wiring the wastegate shut, maxing out the fuel screw and mashing your skinny pedal into the carpet, it's not advisable, and the results are nothing at all like a turbo that can flow enough air to ~efficiently make 20 lbs of boost! If you are seeing 9 lbs without totally slamming it, you are probably "there".
i have a banks. not sure if the fuel was turned up on it when it was put on, it would run around 9lbs max unloaded. turned my fuel up one flat and the thing spools WAY quicker goes to 10 lbs now, only see about 800* tops.
havent tried it loaded, if it all goes well with the trailer ill turn it up another flat and adjust the waste gate to around 12-14.
I'm only able to hit high teens when towing a good load at work and that consists of of 1500gal vacuum tank system. Usually when pulling up a good hill. I do downshift and take the load off to keep from cooking the turbo, most I hit is about 900 degrees... Better than the previous driver that would take it to 1200 degrees.
BS. Intercooling ADDS power, it does not rob it. It can create a little bit of turbo lag, and your boost psi drops, but that is part of the physics of cooling a gas. Many owners claim adding IC is the second biggest power adder besides adding a turbo in the first place, as well as better mpg and lower egt's. Win!
