Fuel spewing out of the filler tube on front tank
I'll explain the scenario, and see if you can figure this out. I was getting a lean fuel error code on the check engine light. My front tank was leaking very slightly, and when I tried to start it with front tank selected, it would sputter and spit. When I switched to the rear tank and reset the code, the light stayed off, and it started just fine. So I figured I just had a leaking front tank and I'd fix it later. I still had a full front tank, so to empty it, I would switch it to the front while I was on the highway, because it ran fine then (it only sputtered when I stopped). The fuel gauge showed full (like way full) as I drove. So, today, I notice fuel dripping from the door on the front fuel tank. I started to take the cap off, and fuel started spewing from the top of the filler tube. I'm starting to wonder if it's not the tank and something else. What would cause this issue?
BTW, I have another issue with 4x4 that I posted in another thread if your interested.
Not sure if that explains what you're seeing?
was a little confused by the sequence of events as you listed them - but will say as I just said in another post - there is a fairly common problem with the dual tanks where if you run off the REAR tank - the return gas can end up dumping into the FRONT tank - possibly making it overflow if it's full.
So, anyone know how or why fuel gets pumped from rear to front??
OK, I'll search. Is the fuel delivery module inside the tank - like the sender, pump, and FDM all in one piece?
Phobia16V
36
01-18-2021 04:01 PM
wrightme43
08-26-2012 08:18 PM
Penrider
05-10-2010 03:02 PM
TJS96F-150
12-10-2007 03:02 PM
Greg A.
03-07-2000 09:43 AM
