2008 Expedition factory installed remote starter giving 5 beeps and not working - Ford Truck Enthusiasts Forums
2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Old 07-02-2013, 12:09 PM
Revrend O'Malley Revrend O'Malley is offline
Revrend O'Malley is starting off with a positive reputation.
I have a 2008 expedition with a factory installed remote starter. One little keyfob with one button. My truck was running the other day and I depressed remote fob until it beeped 1 time and kept the truck running so I could pull the keys and lock the truck. A few minutes passed and the truck shut itself down as it normally does. I re-depressed the fob to restart the vehicle and the truck beeped at me 5 times and hasn't worked and beeps 5 times I press fob ever since.
Any thoughts?
Thanks<!-- google_ad_section_end -->
Old 07-02-2013, 03:22 PM
RI-Matt's Avatar
RI-Matt RI-Matt is offline
RI-Matt is starting off with a positive reputation.
Are you sure it's 5 beeps??
5 honks/beeps means the remote start is sensing the key is in the ignition. My guess would be the SecuriLock/PATS unit is at fault.
For future reference.
2 honks = Hood is open or brake is depressed
3 honks = One of the doors is open
4 honks = Tach is not programmed
5 honks = Key is in ignition
6 honks = System is in Service/Valet mode
Matt
Old 07-02-2013, 03:42 PM
Actually SIX beeps..
Hey Matt,
I just tried again - it is actually SIX beeps. Thoughts on how to remove from Valet mode?
Thank You!
Matt
Old 07-03-2013, 07:24 AM
RI-Matt's Avatar
To return to normal mode:
Insert key and turn to ON or RUN ( foot OFF brake )
Press the remote start button on remote 3 TIMES.
Horn will honk 1 TIME indicating system is out of Valet Mode.
Remove key and test to make sure system functions normal.
Also, when using the "quick stop" feature make sure that your foot is not accidently on the brake as this can case the system to enter valet mode.
Matt
Remote start acting up Eightyfive Flareside 2004 - 2008 F150 4 12-07-2016 10:26 AM
Remote start issue 07fx4150 Modular V8 (4.6L, 5.4L) 2 02-24-2016 02:09 PM
2008 Expedition Remote Start - 6 beeps poppadon56 2007 - 2014 Expedition & Navigator 0 04-28-2015 02:01 PM
Bi-Directional Remote Start Software Update dgouch 2007 - 2014 Expedition & Navigator 0 01-13-2015 08:51 AM
Factory remote start doesn't work after new keys LucasMN 1997 - 2003 F150 3 10-12-2012 10:36 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
