6.2L tuner question - Ford Truck Enthusiasts Forums
6.2L V8 Discuss the 6.2L V8
6.2L tuner question
Old 07-02-2013, 12:11 PM
shane52966 shane52966 is offline
shane52966 is starting off with a positive reputation.
6.2L tuner question
Received my SCT tuner from 5Star yesterday, was reading the instructions and just wanting to be sure that if I install the 87 octane tune, that is the only fuel I can run with that tune installed? If I were to put say 89 or higher in it could damage the engine? I am new to this and just wanting to be sure.
Old 07-02-2013, 03:15 PM
22rimfire 22rimfire is offline
22rimfire is gaining momentum as a positive member of FTE.22rimfire is gaining momentum as a positive member of FTE.
I'll preface my answer by saying a quick call to 5star will confirm the answer for ya, but here's my .02 worth; Running higher octane won't hurt a thing, but if you want to burn premium, by all means run the 91 (Or 92, whatever you have), tune. You'll be glad you did! You did get a premium gas tune included as well, didn't you??
Old 07-02-2013, 03:26 PM
RAPR's Avatar
RAPR RAPR is offline
RAPR is starting off with a positive reputation.
No need to call 5star. running a higher octane than a vehicle or tune is designated for is perfectly fine. The higher octane fuels prevent early detonation in high compression situations. If the engine is tuned for 87, it will not compress the fuel mixture as much before combustion as compared to an engine tuned for 93 octane.
A higher compression tune creates more power from the fuel mixture, but if you do not have a high enough octane level the fuel with self ignite under the higher compression (prematurely) and cause the engine timing to get thrown off (also known as knocking). If that happens, damage could happen....but lucky most current vehicles include our truck, has 'knock sensors'. If the 'knock sensor' is triggers, the truck automatically delays the timing of the valves to reduce the compression cycle.
I'm not 100% how the knock sensors behave due to a tune, as the program writter could change the behavior.
To make a long story much shorter.....you are ok with running a higher octane than needed.
Tuner Question Sparky83 Aftermarket Products 2 08-31-2015 08:41 PM
Used Tuner preppypyro 6.4L Power Stroke Diesel 4 06-14-2013 06:09 PM
Tuner questions majkthreads 6.7L Power Stroke Diesel 44 04-03-2013 03:39 PM
Best tuner? ramrod7373 1994.5 - 1997 7.3L Power Stroke Diesel 12 03-16-2013 03:36 AM
Saving Custom tunes (sct) BIRDMANN79 Computer Chips & Tuners 3 04-11-2012 07:02 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
