Transmission type '93 F-150 - Ford Truck Enthusiasts Forums
Old 06-11-2003, 05:49 AM
Adrienc9 Adrienc9 is offline
Adrienc9 is starting off with a positive reputation.
How do I tell what type of automatic transmission I have on my 1993 F-150? I have the overdrive push button on the end of the gear shifter. I am having some weird things happen with it. Sometimes it shifts really hard going into second gear. Sometimes shifting in the higher gears, the engine RPMs go way up to about 4000 and then all of a sudden the tranny will catch. Other times it works great! Any ideas?
Old 06-11-2003, 10:59 AM
etucker etucker is offline
etucker is starting off with a positive reputation.
i think it may be a E40d tranny like in my 90 f250 I am having a little bit of the same problem. i am thinking it may be tranny fluid needing changed. i will let you know if that fixes my problem.
Old 06-11-2003, 01:18 PM
Please do let me know if that works. I just bought the truck a few months ago and am having some oil pressure problems with the engine right now so I am working on that first.
Old 06-11-2003, 02:05 PM
jimandmandy jimandmandy is offline
jimandmandy has a great reputation on FTE.jimandmandy has a great reputation on FTE.jimandmandy has a great reputation on FTE.jimandmandy has a great reputation on FTE.jimandmandy has a great reputation on FTE.
You could have an E4OD or 4R70W(AODE-W). Both use all-electonic controls, so normal automatic transmission diangosis may not find your problem. Get a code scanner or have someone read diagnostic codes for you. Based on my problems with an E4OD, your fluid pressure is being regulated high in an attempt by the computer to compensate for another weak component in the transmission. Sometimes, just loose or dirty electrical connectons are the problem.
Jim
Old 06-11-2003, 11:03 PM
Ryan50hrl's Avatar
Ryan50hrl Ryan50hrl is offline
Ryan50hrl is a splendid one to beholdRyan50hrl is a splendid one to beholdRyan50hrl is a splendid one to beholdRyan50hrl is a splendid one to beholdRyan50hrl is a splendid one to beholdRyan50hrl is a splendid one to behold
check and make sure your valve body is tight when you change the fluid.
Old 06-12-2003, 12:46 PM
LxMan1's Avatar
LxMan1 LxMan1 is offline
LxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant future
Could be the neutral safety switch. This switch also tells the ECM what gear you are in. I haqd to replace the one on my Windstar because it quit shifting all together. My freind had to replace one on his Sable because you could be driving down the highway and it would throw itself into low gear for no reason. Replaced the switch(located on the tranny behind the shifter linkage) and both are fine to this day. It was about $25 at Auto-Zone.
Jimmy
Old 06-12-2003, 12:50 PM
Actually there was a code showing the neutral start code but I didn't think it could be that. Maybe I will try that too.
Old 06-17-2003, 10:41 AM
well adrienc9,
this weekend I changed the transmission fluid. it just might be internal but all the gears that do work shifts in nice and smooth have not actually drove the vehicle on the road yet though just 10ft forward and backwards.
Old 06-17-2003, 07:51 PM
Thanks I am still working on my motor right now but the tranny is next.
Old 06-18-2003, 03:29 PM
t4kne t4kne is offline
t4kne is starting off with a positive reputation.
My 93 F150 was shifting very hard. Turned out to be a sticking govorner. I dropped in a pint of Lube-Tech and the problem was gone in 5 minutes of idling.
I had tried replacing the transmission filter and fluid and this had no effect at all. This Lube -Tech stuff worked great.
Old 06-20-2003, 08:17 AM
havack havack is offline
havack is starting off with a positive reputation.
Quote:
The 93 has a Manual Lever Position Switch not the NSS. It lets the ECU know that it is in park or in Neutral for starting as well as each gear except O/D.
It is the E4OD and not the 4L70W. That one came in 97 I think, some in 96.
Old 06-20-2003, 10:58 PM
steve83's Avatar
steve83 steve83 is offline
steve83 is starting off with a positive reputation.
The 4R70W was used as early as '95; possibly earlier. The TRANS code on the door sticker will tell for sure, though. The E4OD code is "E" and the 4R70W code is "U". You can also tell by the pan shape.
Old 06-29-2003, 01:19 PM
Pickup Man Pickup Man is offline
Pickup Man is starting off with a positive reputation.
Adrienc9 Replaced the mlps on my 94 5.0 4r70w because it would go to neutral between 3-4 after going down hill(no load) and start to pull again (load). It didn't do it all the time and you couldn't make it do it. Usually most often when hot and pulling load (boat). Takes 10min and cos t $70. Just do it! PM
'51 - '52 transmissions alamartina 1948 - 1956 F1, F100 & Larger F-Series Trucks 22 11-24-2013 01:12 PM
Transmission slips only sometimes? ravens fan Clutch, Transmission, Differential, Axle & Transfer Case 4 11-05-2012 11:29 PM
1952 F6 Transmission - Fix or Replace? hulaman 1948 - 1956 F1, F100 & Larger F-Series Trucks 8 09-07-2010 08:45 PM
Manual Transmission hard to shift dlsmithsr 1987 - 1996 F150 & Larger F-Series Trucks 8 12-02-2009 06:19 PM
E4OD Shift Hunting omio Clutch, Transmission, Differential, Axle & Transfer Case 3 07-13-2004 09:33 AM
Tags
1993, 4l70w, 4x4, 93, case, code, f150, hard, neutral, replacing, shifts, switch, trans, transfer, transmission, xlt
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
