EVAP vent solenoid - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
EVAP vent solenoid
Old 07-02-2013, 10:12 AM
enduroguy enduroguy is offline
enduroguy is starting off with a positive reputation.
EVAP vent solenoid
Hello everyone, I have a 99 F250 v10 that I haven't owned for very long. My check engine light is on and I have pulled code p455-EVAP leak detected. While following the hose system looking for potential problems I found that the EVAP vent solenoid (located on the back of the EVAP canister) has what looks to be a very short piece of hose on it that doesn't go anywhere. I am wondering if this is supposed to be connected to something, or if there is supposed to be some sort of small filter on it. I haven't been able to find any useful diagrams or pictures of this.
Old 07-02-2013, 12:20 PM
projectSHO89 projectSHO89 is online now
projectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant future
That's the inlet hose to the vent solenoid. It's supposed to be open.
Old 07-02-2013, 01:06 PM
Wolfboro's Avatar
Wolfboro Wolfboro is offline
Wolfboro is gaining momentum as a positive member of FTE.
I have a repair manual covering 2000 Superduty F-250-550/Excursion/ F-53 Motorhome Chassis .
Here is what it says for error code p0455 at Evaporative Emission Diagnostics :
<table width="96%" border="1" rules="groups" cellspacing="0" cellpadding="3"><tbody><tr><td colspan="2">CHECK FOR DIAGNOSTIC TROUBLE CODE P0455 OR P1443</td></tr></tbody><tbody><tr valign="top"><td valign="top"></td><td valign="top">
</td></tr><tr valign="top"><td></td><td>
  • Is DTC P0455 present?
Yes GO to B2.
<table width="96%" border="1" rules="groups" cellspacing="0" cellpadding="3"><tbody><tr><td colspan="2">B2 VISUALLY CHECK FOR GROSS EVAP SYSTEM LEAKS </td></tr></tbody><tbody><tr valign="top"><td valign="top"></td><td valign="top">Check for the presence of a fuel filler cap. Do not tighten or check for correct installation at this time.
</td></tr><tr valign="top"><td valign="top"></td><td valign="top">Check the input port vacuum and EVAP return tube are connected to the EVAP canister purge valve.
</td></tr><tr valign="top"><td valign="top"></td><td valign="top">Check that the canister vent solenoid is correctly attached to the EVAP canister.
</td></tr><tr valign="top"><td valign="top"></td><td valign="top">Check for disconnected or cracked fuel vapor hoses or tubes between the intake manifold and following components:
  • EVAP canister purge valve
  • EVAP canister
  • Fuel vapor vent valve assembly
  • Fuel vapor control valve tube assembly
</td></tr><tr valign="top"><td valign="top"></td><td valign="top">Check for damaged fuel tank or fuel filler pipe.
  • Is a concern with a hose, tube, connection or valve visually evident?
Yes REPAIR or INSTALL new EVAP components as necessary.
(This is a short version just to give you some problem areas to check).
Good luck,
</td></tr></tbody></table>
Old 07-03-2013, 08:24 AM
Thanks, hopefully I'll be able to figure his out.
Old 02-02-2015, 10:00 AM
Overdue update on how I fixed this incase someone runs across the same problem. The gasket on top of the fuel tank wasn't sealing properly. It was apparently getting worse, as I filled the tank one day and had gas running out from under the truck. I pulled the bed to see what was happening, used a rag and an air hose to slightly pressurize the tank and found the leak.
Help locating EVAP hose gxtr 1999 to 2016 Super Duty 1 01-21-2017 12:38 PM
1999 Explorer - Code P1451 EVAP System Canister Vent Solenoid Circuit Malfunction tapper95 Explorer, Sport Trac, Mountaineer & Aviator 25 07-09-2016 12:30 AM
Fuel tank vent vapor valve, two ports? failed smog 1994 Ranger brianm767 Ranger & B-Series 0 02-13-2016 09:30 PM
2006 Evap Emissions P0446 - evap vent valve & broken wires? scrnchr Escape & Escape Hybrid 2 06-02-2014 01:46 AM
Gas getting into evap canister steelear 1987 - 1996 F150 & Larger F-Series Trucks 6 04-03-2014 11:33 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
