Patch Panel Comparison F-100/250/350 to F-500/600 - Ford Truck Enthusiasts Forums
Old 07-01-2013, 10:43 PM
Bobs65F600's Avatar
Bobs65F600 Bobs65F600 is offline
Bobs65F600 is starting off with a positive reputation.
Ok...here's a longish question that may or may not be easy to answer. I know that my truck (F-500) has larger wheel openings than the F-100/250/350. Here's the question: Is the F-100 front fender (particularly the lower part, near the door) the same size with the exception of the larger lip/smaller wheel opening for the "light" trucks and the "medium" trucks?
I was wondering if using a patch panel for the F-100 would work, with a little cutting and bending to shape the wheel opening while retaining the shape of the lip/contor line. I was thinking that if the F-100 fender could be overlayed on mine that I could trace the opening cut line, leave myself some extra metal for finishing, cut the F-100 patch panel, use a metal brake to provide a clean edge that matches the good part of my existing fenders, then graft them together and cure the cancer that caused a hole in both front fenders.
Maybe one of you owns both types/sizes of trucks and could tell if a modified F-100 patch panel would work for me. Hope that makes sense!
Thanks!
Old 07-04-2013, 12:12 PM
Bobs65F600's Avatar
Got a reply from Dennis Carpenter's folks. Looks like the patch panel for the F-100/250/350 would work if I opened up the wheel well to my size.
Old 07-04-2013, 12:33 PM
spurredon's Avatar
spurredon spurredon is offline
spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.
Good to know. Glad it's going to work out!
Old 07-15-2013, 03:20 PM
Bobs65F600's Avatar
Quote:
Thanks! It's a long term project, but it's good to know I don't have to fabricate this stuff myself. Modification is a LOT easier!
Rust repair and patch panel forming AXracer 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 12-02-2014 11:43 AM
Parting out 1973 F100 Ranger XLT Short Bed fomoco111 1973 - 1979 F-100 & Larger F-Series Trucks 2 04-14-2014 06:58 PM
my 53 Snowking Manitoba / Saskatchewan Chapter 9 02-05-2007 10:33 PM
'56 F-100; gap between bed and fender barbsbuddy 1948 - 1956 F1, F100 & Larger F-Series Trucks 8 01-08-2006 08:58 PM
Patch Panels? wolverineflight31 1961 - 1966 F-100 & Larger F-Series Trucks 1 01-02-2002 05:34 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
