What to do with 1999 gas? - Page 2 - Ford Truck Enthusiasts Forums
Old 07-02-2013, 06:37 AM
truckdog62563's Avatar
truckdog62563 truckdog62563 is online now
truckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud of
I'll bring it up at the Saturday breakfast table and see what my two shop owner buddies say, one who is retired and recycled his old oil, and the other who heats with it. I know they both over the years have willingly and knowingly taken my jugs of old oil mixed with dead gas and kerosene. Stu
Old 07-02-2013, 07:48 AM
EffieTrucker's Avatar
EffieTrucker EffieTrucker is offline
Kentucky Chapter Member
EffieTrucker is a splendid one to beholdEffieTrucker is a splendid one to beholdEffieTrucker is a splendid one to beholdEffieTrucker is a splendid one to beholdEffieTrucker is a splendid one to beholdEffieTrucker is a splendid one to beholdEffieTrucker is a splendid one to behold
Quote:
Originally Posted by pineconeford View Post
If you can run something with your 14-year-old gas in it....and I'll bet you could, you'd be my hero.
I have a 1967 M35A2 (Military Deuce and a half) that loves the stuff. I pour it through a paint filter and dump it in.
Old 07-02-2013, 08:22 AM
DR Smith's Avatar
DR Smith DR Smith is offline
DR Smith has a great reputation on FTE.DR Smith has a great reputation on FTE.DR Smith has a great reputation on FTE.DR Smith has a great reputation on FTE.
I Drained the pontoon boats tank of year old mixed 2 stroke gas of 15 gallons,and have been using it in the lawn mower and gator mixed with fresh gas, Haven't even seen any smoke.Can't tell the difference in the way it runs.
Old 07-02-2013, 11:51 AM
old_dan's Avatar
old_dan old_dan is offline
old_dan has a great reputation on FTE.old_dan has a great reputation on FTE.old_dan has a great reputation on FTE.old_dan has a great reputation on FTE.old_dan has a great reputation on FTE.
Quote:
Originally Posted by bigwin56f100 View Post
Farmall cub=low compression no wonder it runs on anything, heck maybe I should try a little waste oil!
That makes your Farmall a hybrid....it runs on gas...and a little bit of oil!!
Old 07-02-2013, 12:33 PM
tinman52's Avatar
tinman52 tinman52 is offline
Welder User
tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.
Set something on fire! Works especially well on any of the ex wife's stuff she left behind.....
Old 07-02-2013, 01:32 PM
needhelp49 needhelp49 is offline
needhelp49 is gaining momentum as a positive member of FTE.
you can always give it to your teenage girls boyfriend so he has enough gas to make it home
Old 07-02-2013, 01:49 PM
HT32BSX115's Avatar
HT32BSX115 HT32BSX115 is online now
HT32BSX115 has a great reputation on FTE.HT32BSX115 has a great reputation on FTE.HT32BSX115 has a great reputation on FTE.HT32BSX115 has a great reputation on FTE.
Quote:
Originally Posted by 85e150six4mtod View Post
I have been told more than once they do NOT want ANY gas mixed with the waste oil. Adding this amount will make some low grade napalm and would invite disaster.
YES YES YES!
I have a waste oil furnace in my shop. You run a SERIOUS risk of blowing it and you UP....... putting in ANY fuel that will produce an ignitable vapor in a waste oil furnace is extremely dangerous!!!!!!!!!!!!
DON'T DO IT!!
I have mixed very old gasoline with new gasoline (10:1 ratio or higher) and just burned it in any car or truck.
(I wouldn't use it in a marine engine though)
Old 07-02-2013, 03:03 PM
Doc's Avatar
Doc Doc is online now
Doc has much to be proud ofDoc has much to be proud ofDoc has much to be proud ofDoc has much to be proud ofDoc has much to be proud ofDoc has much to be proud ofDoc has much to be proud ofDoc has much to be proud of
Quote:
Quote:
My two favorite answers so far.
Personally, I would never try to re-use old gasoline even if I was mixing it with fresh gas. I have enough fuel and carburetor issues of my own making. I certainly don't need to take a chance on creating more with somebody's old gasoline. I certainly would never put it into used oil that somebody might use for one of those shop heaters.
Old 07-02-2013, 03:46 PM
Capt'n Phillips's Avatar
Capt'n Phillips Capt'n Phillips is offline
Capt'n Phillips has a great reputation on FTE.Capt'n Phillips has a great reputation on FTE.Capt'n Phillips has a great reputation on FTE.Capt'n Phillips has a great reputation on FTE.Capt'n Phillips has a great reputation on FTE.
I have a motorcycle shop and run into this all the time. I save it and mix it with waste oil and call it "Boyscout In A Can". I use it for starting fires either in the wood stove or camping or??? And yes...it does work well as a weed killer. Like WD-40...it works on all kinds of things.
Capt'n
Old 07-02-2013, 07:15 PM
GLR's Avatar
GLR GLR is offline
GLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputation
Just got through draining 3 year old gas out of a car I'm scrapping. Pretty urine color. Added some stabil , will mix it 50-50 with fresh. That will keep the mower going for a while (if the rain ever lets up). Car was running ok before I dropped the tank.
Old 07-02-2013, 09:58 PM
Aarons54f100's Avatar
Aarons54f100 Aarons54f100 is online now
Aarons54f100 has a good reputation on FTE.Aarons54f100 has a good reputation on FTE.Aarons54f100 has a good reputation on FTE.
This right here...
Quote:
Originally Posted by craftsmangary View Post
It makes good weed killer, lol
Old 07-02-2013, 11:27 PM
Holehawgg's Avatar
Holehawgg Holehawgg is offline
Holehawgg is gaining momentum as a positive member of FTE.
I`m with Doc or Tinman on this. Evaporation is cool but lighting something up is even better. Works great for starting the backyard firepit. Just duck when you throw the match in and let it burn for a bit before you cook your hot dogs or marsh mellows on it. Tastes funny otherwise...
1999 f250 Jay317 1999 to 2016 Super Duty 6 01-18-2015 08:59 AM
F 350 v 10 1999 super duty gas hog! leblancedward New Member Introductions 3 01-28-2008 04:34 PM
Gas Octane boomer99 1997-2006 Expedition & Navigator 6 12-09-2004 04:35 PM
82 F-150 gas tanks jwf1999 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 6 07-01-2004 09:29 AM
Engine Swap deweyh 1997-2006 Expedition & Navigator 1 08-10-2000 08:50 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
